Old 11-04-2012, 02:04 PM #16
77'911 77'911 is offline
77'911 is on a distinguished road
Fuel pump replacement....
Originally Posted by Hyde802 View Post
Dam thats a clean lookinh tank!
Thanks. I had just washed off the tank before installing the new f-pump and seal(see pic).
The truck also got a new regulator and injector reseal which really improved the trucks performance. Darn ethanol, along with age is doing a number on the fuel systems to these older vehicles.
regards
77'911 is offline   Reply With QuoteReply With Quote
Old 10-08-2018, 08:39 AM #17
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Originally Posted by SV_Dude View Post
You're 100% correct. Unless the ECU gets the signal from the AFM that the air vane is open and air is entering the engine, the pump will not turn on. This is why I suggested to run a hot wire to the pump and let the pump do the work for you.
Good call on the fuel line idea, baffle had me stumped too. To get power to the pump with key at "run" position jump FP and +B in the diag box, bypasses your circuit opening relay/AFM signal.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 10-08-2018, 08:58 PM #18
grousehunter 61 grousehunter 61 is offline
Real Name: rodger
grousehunter 61 is on a distinguished road
Real Name: rodger
why are you dropping your tank??? if its to remove the fuel pump, cut a hole under the back seat on the passenger side...
grousehunter 61 is offline   Reply With QuoteReply With Quote
Old 10-10-2018, 12:51 AM #19
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
5 year old thread...
1992 gas tank has a drain plug...for future reference.
Ethanol sucks. Turns gas gel with age...great idea there feds...
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 04:43 PM #20
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
want to re-open this thread. I have an 01 runner 3rd gen and was wondering how to remove the fuel from the tank. Is through the filler hose way the best option? I've read there is a baffle. I have about 1/2 tank of fuel in the tank and that's heavy for my standards. My jack could hold the weight of the tank but ill be doing this job myself so a fairly empty tank would be great. Any ideas?
cashflow50 is offline   Reply With QuoteReply With Quote
Alarm system draining my Batt... Bizz 3rd gen T4Rs 9 10-23-2012 01:33 PM
Something is draining my DH Platinum Battery!! JWaldz 3rd gen T4Rs 7 08-20-2012 08:28 PM
Battery Draining!? Need some info. daugherty83 3rd gen T4Rs 9 09-20-2009 09:33 PM
battery draining - help please! jerrysc99 4th Gen T4Rs 4 08-07-2009 01:39 PM
draining atf in 2004 4speed trans RICK Maintenance/Detailing 2 01-08-2005 11:42 AM
