Originally Posted by kpnavarro
Thanks for all the imput, I found a full set of Energy Suspension poly bushings for the entire car on amazon for $139 on Amazon.
If your pulling the front a-frames, you might consider doing the upper and lower ball joints. Since your pulling the torsen bar, you might also go to Toyota to get new adjust and bolt hardware. This is a stress point that goes on these trucks. I also upgraded our torsen bars to 25mm Sway-a-way units, but it does stiffen it up a bit. We like it for highway and road use(more high speed stability).
regards
