Originally Posted by KidVermicious
He probably got water somewhere it shouldn't be. Wrap your electronics in plastic and you'll probably be fine. A better idea is to fix leaks right away so your block doesn't get filthy .
Oh, and I like Purple Power better than Simple Green, but either works.
Agreed.... avoid the intake and distributor... maybe even the alternator from being directly sprayed.
does it accumulate right on the inspection plate and then drip onto the 3rd? sounds exactly like mine. My parents noticed I had leaked oil all over (though I knew it had been leaking) so I finally took a look. cleaned it up and waited for it to leak. The only place is right there at the bottom of the inspection plate.
Granted mine is a 3.0
I noticed I was almost 2 quarts low so I bought some 10w-30 castrol high mileage oil to try it out. no leaky.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
