Old 01-05-2013, 10:35 AM #1
tundrayetti's Avatar
tundrayetti tundrayetti is offline
tundrayetti is on a distinguished road
What is this called?
It mounts under the front of the intake manifold. I'm considering removing it and re-routing my water lines. But what is it called and what is its purpose?
88 22RE
Play stupid games.....win stupid prizes
tundrayetti is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 12:09 PM #2
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
That's your idle air controller, I believe. It's integrated in the upper intake plenum (or throttle body? I forget) on the late model 22REs, just switch plenums.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 01:22 PM #3
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
That is the idle air control valve. It uses the coolant temp to determine if the idle should be raised or not when the engine is cold. When the coolant is cold, the vacuum line that goes the the underside of the throttle body will open the throttle body a little bit to allow more air to enter the cylinders.. That will allow the idle to be raised when the engine is cold. The plug on the back of it goes to the ECU and tells the ECU to give the engine a little bit more gas so the engine doesn't run too lean.
I wouldn't get rid of it. It's a necessary part to have.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 09:51 PM #4
Thanks guys. I took your advice SV, and left it installed.
88 22RE
Old 01-05-2013, 10:00 PM #5
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Good call! Your engine will still start and run when cold without it but it won't run as good when cold and won't warm up as fast. It doesn't reduce any performance to keep it so there really isn't any real good reason to delete it.
Old 01-06-2013, 02:31 PM #6
Makes sense. I'm glad you were able to explain its function. Otherwise, it was gonna get gone!
88 22RE
Old 01-06-2013, 03:02 PM #7
Real Name: Kevin
Real Name: Kevin
It can get gone, or at least moved. Look up the late-model plenum swap.
Old 01-06-2013, 03:06 PM #8
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Got a link for this swap? I'm curious what the benefit would be.
Old 01-06-2013, 03:12 PM #9
Real Name: Kevin
Real Name: Kevin
Here's the one I bookmarked, but they're all over: Siesta Off Road: Tech - Late Model 22re Throttle Body Swap
Lots of guys claim a performance boost with the straighter intake - I call bullpucky on that. But it does eliminate the IACV with a system that is supposed to be more reliable and definitely removes a bit of clutter from under the plenum, leading to easier access under there. I couldn't find a late-model plenum quick enough when I was doing my head or I would have swapped it out then.
Old 01-06-2013, 03:19 PM #10
Thanks Kid. I'm definitely interested in looking into that swap. As for right now, I'm just trying to get what I have put back together and running.
88 22RE
Old 01-06-2013, 03:27 PM #11
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
If it has better airflow then it will increase the power. How much...? Who knows, maybe a pony or two. But with a gutless 22re, every bit of power counts. As long as it's a cheap mod then I guess it could be justifiable. Just be careful, once you start on the road to adding power to the 22re you'll never stop. Next thing you know you'll be like me and have 3k into an engine and it's still a 22re that doesn't put out much power. I had about 3k into mine that still had less than 150hp.
If you ask me, I would suggest to just delete the EGR and leave the rest stock. The only reason I say to delete the EGR is for simplicity. The less moving parts under the hood means more reliability. If I had to do it again, I would have done nothing more than a mild cam and the street rv head.
Old 01-06-2013, 03:36 PM #12
Real Name: Kevin
Real Name: Kevin
I don't believe it has better airflow, though. The intake is in one spot and the throttle body is in another, and the air must bend to get from one to the other. Straighten out one bend and you're forced to make another bend sharper. I'm no hydrodynamic engineer, but I bet that actually hurts airflow. Probably not enough to matter either way, but if/when I swap my plenum, it'll be to clean up the engine bay, not for power gains.
I wish I could delete my EGR, but we have strict emissions to pass here.
Old 01-06-2013, 03:39 PM #13
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Move to Colorado! Awesome wheeling and no emissions in El Paso County.
Old 01-06-2013, 03:46 PM #14
Real Name: Kevin
Real Name: Kevin
Would I have to buy a second gen to live in El Paso county? I have standards to maintain, you know.
Old 01-06-2013, 03:50 PM #15
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Haha... funny! I did have a 1st gen for a while ya know, it did some pretty good wheeling here.
My wife just called... jediwebdude 4th Gen T4Rs 13 11-20-2012 11:27 PM
what is this piece on uca called? CNJ Runner 4th Gen T4Rs 8 07-29-2012 10:10 AM
WTF is this called? teamJacob 3rd gen T4Rs 9 01-24-2011 09:35 PM
Can anybody tell me what this is called? ATXsmoke-a-thon 4th Gen T4Rs 5 07-13-2010 03:31 PM
