Hyde802
Old 02-23-2021, 08:47 AM #226
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Originally Posted by Neill.Casey View Post
Any chance you might know if I can use the ring and pinion gear out of the rear diff on my late 89 sr5 in the rear diff of a 2002 sr5?
I dont know for sure, but it should be the same. Heres some good diff info: LC ENGINEERING Differential Tech
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 01:50 PM #227
DrewHealy DrewHealy is offline
DrewHealy is on a distinguished road
At what point do you need/ should go to beefier axles??
DrewHealy is offline   Reply With QuoteReply With Quote
Old 03-01-2021, 02:14 PM #228
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Thats a pretty loaded question. Haha. Depends a lot on driving style and where you wheel. I feel my set up is pretty good for my tire size, I really wanted to stay narrow. But any more tire size or horse power and I probably should have went with one tons.
IG: rattlewagon
Old 03-01-2021, 10:10 PM #229
Howitzer's Avatar
Howitzer Howitzer is offline
Howitzer is on a distinguished road
Howitzer's Avatar
I like the creativity with "sourcing" the chains from an F550. Badassery at its finest!
87 4Runner Diesel swap in progress- stay tuned for writeup
If Nobody From The Future Comes And Stops You, How Bad Of A Decision Can It Really Be?
Howitzer is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 09:10 AM #230
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Thanks! They were free lol. I figured Id try my hand at making some before buying some. tractor chains are expensive!
Got the rear shocks and bumps re done and tested. monroe 13" "f250" shock and f250 towers again, but this time so the shock doesnt bottom out. Made some bumps from some scrap and some energy suspension bump stops. Same ones Im running in the front. For $13 for the pair, you cant beat em.
I ended up making them a bit to long, but just trimmed the bump stop to compensate. they hit the u bolt plate right between the nuts when the leaf is just past flat.
And awaywego.
Trees are for traction buddy.
I was told there would be more snow here (its about 2 hours south of my place) thats why the chains are still on. Another week or so up here and they will be off for the season.
IG: rattlewagon
Old 03-25-2021, 10:04 PM #231
Howitzer's Avatar
Howitzer's Avatar
You're giving me a lot of inspiration! I picked up a 89 pickup as a parts truck for the wife's 90, and now that all that remains are axles and a carcass I am entertaining the idea of making a bush truck to beat up around the woods. I might need to borrow an idea or two from you, thank you !
Old 04-23-2021, 07:55 AM #232
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Beadlocks are finally happening. Had a friend with a shop cut and weld them on for me. He sent me these pics, Ill be picking them up today and hopefully painting and mounting them this weekend.
IG: rattlewagon
Old 04-26-2021, 09:06 AM #233
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Heres a shot of my beat old tires. I've been running them for 6 years. 3 have tubes in them. Still have ok tread, but wicked dry rotted. This is the worst one. Thats the tube coming out through that gash, been wheeling it like tis for about a year and a half. Keeping my old tires/rims as spares for now.
And on to the new
My friend with the table did the welding also, as hes much better than I am. Also had him close the valve stem hole up so I could move it up to a more accessible part of the rim.
The back side, I used short 1.25/.453 stems and a 7/16th drill bit for the new hole.
They say to use silicone on the bead to help with leaks, but through some webwheelin, I found some one using this stuff. Says its flexable and isnt too hard to dismount the tire if I need to, so I figured id give it a shot. I did both beads just to be sure, and also 2 wraps of gorilla tape on the inner bead. Just trying to be proactive while everything easily accessible.
And together they go.
Im usually an all black everything guy, so the yellow ads a nice pop of color to the truck.
IG: rattlewagon
Old 06-19-2021, 09:27 PM #234
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Broke an inner star/race in an original longfield, which also took the splines off the outer end of the long side shaft. Bummer. Ive been running this shaft since 2014, so hoping it was just tired. The bell still looks good so Im hoping I can rebuild it for a spare.
Also installed some super low buck rock lights.. lol
Some recent wheelin pics:
IG: rattlewagon
Old 03-27-2022, 06:41 PM #235
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Long overdue, but got some real harnesses. Hand me downs from a race car friend. Harness bar welded to the body with some 4x8 plates and some right angle brackets to attach it to the floor using the rear seat mount bolt.
IG: rattlewagon
Old 08-15-2022, 03:10 PM #236
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Been wheeling a bunch.. and the 3.0 is getting a little tired. Shes been nose up too long too much and getting a little knocky. Going to keep limping it along and start prepping a 3.4 to go in. Ive gotten 10 years of solid wheeling out of this ole 3.0.
Toyota crawler in the halfpipe , the jungle - YouTube
Same climb from the other side. Local hard climb (at the jungle in Bethel Vermont) , this was my first time making it. I havent even tried in years because of how quickly it can go bad. But it was hot and the rocks were sticky and the wife and I strapped in and gave it ago.
Toyota climbs the half pipe - YouTube
3.4 time I suppose
IG: rattlewagon
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Don't piss off Hyde... KidVermicious Off Topic 8 10-02-2014 02:47 AM
Mods instructions and builds ? where are the best canopypilot Classic T4Rs 4 12-24-2010 12:00 PM
4Wheeler builds a rock crawling GX470???? Duc Hunter 4th Gen T4Rs 6 01-31-2005 06:47 PM
