Hyde802
Old 01-17-2014, 12:44 PM #46
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Got most of my steering parts in yesterday. Ill have a better update after the weekend, but heres the teaser.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 01-17-2014, 01:29 PM #47
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by Hyde802 View Post
With that out of the way I put the front axle together.
Still need to work the break shims to get the rotor to line up with the caliper. but still..
are you planning to run some inset wheels? the scrub with that set-up is going to be bad. steering effort will be very high.
im building a front 60 so I can do just the opposite, and get the tire more centered over the steering axis.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-17-2014, 02:43 PM #48
brifri01's Avatar
brifri01 brifri01 is offline
brifri01 is on a distinguished road
brifri01's Avatar
I guess by running heims on the pitman you won't have much clearance problem with the frame.
brifri01 is offline   Reply With QuoteReply With Quote
Old 01-17-2014, 03:01 PM #49
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
nevada-I wont be running wheel spacers (IFS hubs), so Its actually just narrower than a stock 85 axle with 2" wheel spacers that everybody and their brother runs, So I should be fine.
Brif- Thats the plan! I should have pics of it together after the weekend.
IG: rattlewagon
Old 01-17-2014, 03:21 PM #50
nevada's Avatar
nevada's Avatar
I hope it works out for you.
its hard to tell but by that pic, it looks like the center line of the tire is going to be way outside the trunions.
I have this going on with my truck. im running very deep backspaced wheels, the scrub is terrible, steering effort is HIGH, and being spooled, turning sucks. it pushes badly.
Old 01-20-2014, 05:48 PM #51
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Heres some comparison pics. These are RuffStuff 7/8th hemis vs the stock 85 tierods.
Mock up.
Going to notch the frame for the bolt. I got it to sit a little tighter, but the overall length of the hemi with the misalignment spacers and bolt is pretty long..
Had to take just a hair off each washer to get the calipers to sit perfect, and they JUST barley clean the inside of the 15" rim. . Tierod is done, but waiting for one joint to come in before I can finish up the drag link.
With the wheel on
IG: rattlewagon
Old 01-26-2014, 10:50 PM #52
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Got my box mounted and frame notched. Going to box in above the notch and the back side of the frame a bit, It will be plenty strong, youll see.
Also made it out into the woods this weekend with some friends, and had some company in the shop
Pictures here: Royalton Hill Snow Run 2014 Photos by ediblecrayons03 | Photobucket
IG: rattlewagon
Old 01-27-2014, 04:54 AM #53
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Pure awesome.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 06:56 PM #54
brifri01's Avatar
brifri01's Avatar
Did you have to cut the core support out a bit?
Old 01-28-2014, 02:20 PM #55
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
brifri- I had to cut out the back of the core support, but the front is still there.
Got my tanning booth set up
Got the frame finished and boxed on all sides and mounted the steering box.
Like a glove.
And the other side. I trimmed the smaller spacer on the drivers side for more up travel but didnt do this side because I didnt need to, but it looks pretty goofy being so tall. There is about 1/8th of an inch between the hemis at the closest point. Plenty of room!
IG: rattlewagon
Old 02-16-2014, 12:52 AM #56
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Steering is done, just add fluid.
Shes sittin on all 4s.
Tire to tierod clearance.
Front had 2ish inches more to droop, other side can go up about another inch. Ill get final travel measurements tomorrow so I can figure out what I need for shocks.
IG: rattlewagon
Old 02-16-2014, 11:38 PM #57
brifri01's Avatar
brifri01's Avatar
Looks great Hyde. Flexes good. Did you flex it to see if the sector shaft hits at full stuff? I'm trying to decide on my placement, and whether it's worth notching frame.
Old 02-17-2014, 08:20 AM #58
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Flexed it out a little better last night with the help of the excavator. Looks like the 12" shocks will work fine for me. Pitman arm clears the frame/springs fine, but the draglink starts to hit the frame on the pass frame rail just after the leafs start to go negative, so instead of notching the frame, Ill just bumpstop it and call it good. The drivers spring hit the bottom of the hemi before the tierod hits the frame, so im going to try grind down the mis alignment spacers a little more, so I should be good there too.
The chevies dont flex as well as I would have liked, but there is no weight back there so ill wait a bit before looking for a different set of springs.
IG: rattlewagon
Old 02-22-2014, 12:25 AM #59
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Intake is a little wonky, but it cleaned up the engine bay, which is what I was after.
Front shock mock up. They are the 12" ford shocks with ford shock towers. Set for 3.5" up travel and 8.5" down. Should be plenty of travel.
Finished pic, Bumpstop is some small daystar (or something) on the spring plate, and bumps against the frame, just before the tie rod hits it.
Rear shock setup. Same Ford shocks and towers, but cut the towers down to fit.
Made a square shaft out of 2 single joint yokes. Used 2.5" Receiver tubing (no inside seam) and some 2" .25 wall tube for the inside part. It required re drilling the mounting pattern on the t case output, but wasnt a big deal. . (more angle than a clearanced CV joint, 42 vs 35) And took it for a drive!
I need to get a small piece of gas line tomorrow after work, but expect some action shots soon, and plans are now being drafted up for a bed/cage
IG: rattlewagon
Old 02-23-2014, 07:58 PM #60
reallifedog reallifedog is offline
Real Name: Jordan
reallifedog is on a distinguished road
Real Name: Jordan
holy crap Hyde thats lookin great!
reallifedog is offline   Reply With QuoteReply With Quote
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Don't piss off Hyde... KidVermicious Off Topic 8 10-02-2014 02:47 AM
Mods instructions and builds ? where are the best canopypilot Classic T4Rs 4 12-24-2010 12:00 PM
4Wheeler builds a rock crawling GX470???? Duc Hunter 4th Gen T4Rs 6 01-31-2005 06:47 PM
