Hyde802
Old 02-23-2014, 09:08 PM #61
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Some out side pics! It will run for a few minuets, then dump fuel into the engine. Going to start by putting the wonky intake back to stockish and checking the AFM and TPS.
You can hear it start run bad right after the rpms come down. Had to shut the camera off to limp it back to the garage.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 02-24-2014, 01:31 AM #62
brifri01's Avatar
brifri01 brifri01 is offline
brifri01 is on a distinguished road
brifri01's Avatar
Looks good. Where did you find the seamless receiver tube at?
brifri01 is offline   Reply With QuoteReply With Quote
Old 02-24-2014, 09:33 AM #63
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Any metal fabrication shop should be able to order it. I got it from Custom Metal Works in Morrisville VT. If that helps you....
IG: rattlewagon
Old 03-05-2014, 11:49 AM #64
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
I think my poor running was a bad 02 sensor/mount. One of the studs broke off the exhaust so the 02 sensor would blow up out of the pipe when I reved it. Taking the pipe off to repair it left me with broken/stripped studs in the exhaust manifold, so that came off so I can get the broken bits out. 1 step forward 2 steps back. Should be able to start putting it back together this weekend.
The flowmaster is beat and getting replace with a punched out Harley sportster muffler. Should be interesting.
IG: rattlewagon
Old 03-05-2014, 12:07 PM #65
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
A motorcycle muffler? Must have video.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 03-08-2014, 12:27 AM #66
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Ill put up a video tomorrow, but I ran it around tonight. New 02 sensor solved the running rich problem. Sportster exhaust is on, and sound pretty much identical to the flow master.
Pulled the front fenders for a bit.. Likin the narrow look.
From the drivers seat, I couldnt see the back of the frame/ rear passenger tire, so I adjusted the back of the cab a bit.
IG: rattlewagon
Old 03-08-2014, 10:14 PM #67
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Played around a bit this am, then drove it down the road to a friends shop for the next step. (less than 2 miles on a dirt road) Ran great, felt really good to drive this again.
Same hill, but first time we went up it this morning
Then down the road to a friends shop for some toooob.
This is just what we got done today, should have it wrapped up by the end of the week.
IG: rattlewagon
Old 03-09-2014, 03:28 AM #68
Real Name: Kevin
Real Name: Kevin
This makes me happy.
Old 03-09-2014, 10:05 AM #69
ajohnson's Avatar
ajohnson ajohnson is offline
ajohnson will become famous soon enough
ajohnson's Avatar
Badass . Nice use of the f250 shock towers, what size shock can you run with that setup?
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
ajohnson is offline   Reply With QuoteReply With Quote
Old 03-09-2014, 02:47 PM #70
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
What do you mean by what size shock? The bolt hole at the top or how long they are? I dont remember off the top of my head, I can get measurements next time Im down there. Ford part number E5TZ-18183-A, can also get them from low range. And the 11.75" shocks (34685). I need to brace the front ones, or they will crack..
Hyde builds some axles.-shock-specs-jpg
IG: rattlewagon
Old 03-09-2014, 04:25 PM #71
ajohnson's Avatar
ajohnson's Avatar
Shock length is what I was referring to. Trying to figure out some mounts for my '87.
Old 03-11-2014, 09:30 AM #72
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
I forgot about the tower measurements. Ill get those tonight
Got some more bent up last night. Did the lower window bar too, but that didnt make it into the picture. The front fenders will go back on with some minor trimming.
I was way more excited about the new pieces leaving the shop, but looking at the pics now, it looks a little "jungle gym-y" but it didnt look that tall in person. Maybe Ill see if I can lower down above the roof a bit tonight. The doors will need work to go back on, as the hinges were removed for tube placement, but the top bar goes over the roof and back a bit, so I can continue to dent up whats left of the cab.
All my buddy does is jeep cages which is all straight bends, this is his first toyota/ exo so were learning.
IG: rattlewagon
Old 03-11-2014, 09:33 AM #73
Real Name: Kevin
Real Name: Kevin
The roof does look just an idge tall, from an aesthetic standpoint.
Are you mostly done, or is there more toob coming? Any plans for a bar on the b pillar? Or something across the middle of the windshield?
Old 03-11-2014, 09:57 AM #74
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Across the windshield, roof crows foot, and a X in the rear hoop, as well as some bracing for the long pieces going from the hoop to the back of the frame.
No b pillar yet. I want to dent the cab up more, cant do that with a b pillar. Maybe an internal one? Also going to add some sort of door bar.
IG: rattlewagon
Old 03-11-2014, 10:18 AM #75
Real Name: Kevin
Real Name: Kevin
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Don't piss off Hyde... KidVermicious Off Topic 8 10-02-2014 02:47 AM
Mods instructions and builds ? where are the best canopypilot Classic T4Rs 4 12-24-2010 12:00 PM
4Wheeler builds a rock crawling GX470???? Duc Hunter 4th Gen T4Rs 6 01-31-2005 06:47 PM
