Hyde802
Old 01-13-2013, 11:16 PM #1
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Hyde builds some axles! 92 V6 on 38s build thread
Photobucket sucks. Im Sorry. Maybe one day ill get them all hosted elsewhere.
After doing the Chevy 63" spring swap, I realized that my axles needed some work to handle the 38" TSLs that Im going to run. Nothing too crazy planned, just some simple durable axles. So here goes nothing.
EDIT: All my photos were hosted on photobucket... there is an add on for google chrome that will re show the pictures.
Ive got a full build thread over on "that other site" too if anyone is interested. HERE
My current rear axle was shot. Had rust holes in the top of diff cover and some pretty bad rock rash on the bottom of the cover. It was yanked and replaced with a housing from a 95 pickup, which I added some TG armorand low profile drain plugs and cleaned off all the tabs I wasnt going to use.
It needed a wheel bearing, so from following this site I chopped up my old housing
And cleaned up and painted
We dont have a press, so I took it to a friends house, and forgot my camera, but this is how it works int he press. Photo taken from the link above
Marlin axle seals
And new shoes and hardware
The gears needed to be swapped because they dont match any other 3rds that I have. So Im taking the spool out of this one and putting it in a v6 4.10 diff.
The bearings were the original ones from 92, and where showing signs of wear, so they are getting replaced too.
Ruff stuff lower shock mounts on the way, and I should have my 3rd update next weekend after I pickup the 4.10s.
85 front axle to come next!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 01-14-2013, 05:03 AM #2
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Wait, what'd you do with the old housing?
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 01-14-2013, 11:30 AM #3
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
I cut 18.5ish" from the flange and welded some material to it to use as a Toyota SST for removing rear wheel bearings in a shop press.
I have another 1/2 of housing if anyone wants the other side to make one?
IG: rattlewagon
Old 01-16-2013, 11:46 PM #4
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Marlin Cralwer front axle rebuild kit backing plate eliminators with Koyo wheel and trunion bearings
IG: rattlewagon
Old 01-17-2013, 05:52 AM #5
Real Name: Kevin
Real Name: Kevin
Oh, ok, I see that now. Very cool! I'd take you up on that other half, but I bet I can find a bent housing local for cheaper than it'd cost you to ship it...
Old 01-20-2013, 10:54 PM #6
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Got the non essential brackets cut off and ground smooth and ran the knuckles through the parts washer to get the 28 years of grease off.
IG: rattlewagon
Old 01-27-2013, 11:04 PM #7
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Trail Gear truss, I slid it down so it touched the spring perch. It took a while only welding 1" stitches at a time, but I wanted to make sure I did not not warp the housing.
Trimmed the bottom perch so it wont hang up on things. TGs 84-85 ubolt flip kit came with 2 round and 2 square u bolts, but looks like it should have came with 3 square ones... ? What everyone else running for a u bolt in that spot right next to the diff?
Bottom gussests, one had to be trimmed to fit over the 85s longer bottom truss.
And the upper knuckle gusset. I added small pieces of plate to connect them to the spring perches. I also added a 3/8ths plate to the drivers side spring perch to bring it level to the passenger side perch. When doing this I made the plate 8" long instead of the stock 5ish to try to help with axle wrap, then boxed it in.
IG: rattlewagon
Old 01-28-2013, 04:56 AM #8
Real Name: Kevin
Real Name: Kevin
Lookin' good!
Old 01-28-2013, 12:47 PM #9
4runnin83 4runnin83 is offline
4runnin83 is on a distinguished road
You sir, (Hyde, not KidV ) are an inspiration.
4runnin83 is offline   Reply With QuoteReply With Quote
Old 01-29-2013, 04:17 AM #10
Real Name: Kevin
Real Name: Kevin
Old 02-21-2013, 11:50 PM #11
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Extended the other spring perch to match, got the last piece of armor on and did a quick paint job.
I have JB weld on the knuckle balls to help smooth the pitting from the rust, Still needs a little more sanding..
Im in the process of a headgasket on an 03 Camry for my new DD , and as soon as thats out of the shop ill be able to roll my truck back in.
IG: rattlewagon
Old 02-22-2013, 12:29 AM #12
ToyoTech's Avatar
ToyoTech ToyoTech is offline
ToyoTech is on a distinguished road
ToyoTech's Avatar
sweet axle build. looks tough as heck and i know its gonna need it. seen your type of wheeling!!! HG on a camry? 4 cylinder? they are know for the head bolts to pull threads out of the head
ToyoTech is offline   Reply With QuoteReply With Quote
Old 02-22-2013, 05:44 AM #13
Real Name: Kevin
Real Name: Kevin
Your welds look like mine!
Old 02-22-2013, 03:28 PM #14
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
THanks! Yeah its the 2AZ. This one made it all the way to 220k before it went. It will get the time-serts and be put back on the road
Kid V.. Is that a good thing? haha. Im no pro welder but definitely getting better.. finally at the point where I dont have to clean them up before I paint them..
IG: rattlewagon
Old 02-22-2013, 03:53 PM #15
Real Name: Kevin
Real Name: Kevin
Yours actually look better than mine. At least you're consistent. I'd have one or two beads that looked professional, and another fifteen or so that looked like a volcano sneezed on my axle.
I bought a much better welder last year and haven't had a chance to play with it much yet. I'm really hoping I'll get some cleaner welds with it.
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Don't piss off Hyde... KidVermicious Off Topic 8 10-02-2014 02:47 AM
Mods instructions and builds ? where are the best canopypilot Classic T4Rs 4 12-24-2010 12:00 PM
4Wheeler builds a rock crawling GX470???? Duc Hunter 4th Gen T4Rs 6 01-31-2005 06:47 PM
