Old 01-19-2013, 03:37 AM #16
77'911 77'911 is offline
77'911 is on a distinguished road
Pull the panel underneath the rear seat and disconnect the harness to the fuel pump and see if it has power to the circuit. Basic circuit tester will work. If it has power, then your pump is probably shot. If it is, you might consider replacing the regulator. The new pumps pressure will blow out the delicate old rubber diaphragm relatively soon after.
regards
77'911 is offline   Reply With QuoteReply With Quote
Old 01-21-2013, 04:12 PM #17
tc4ester tc4ester is offline
tc4ester is on a distinguished road
Ok guys thanks for all the help checked the wiring going to the fuel pump and that was where my problem was. I replaced the fuel pump relay and it's good to go! Ill start a thread soon with pics of the truck and what I'm planning on doing. Thanks for all the advice it definatley helped out
tc4ester is offline   Reply With QuoteReply With Quote
battery , fuel pump , spark plugs , starter
