01-15-2013, 11:24 PM
Please Help!
I just baught a 95 v6 auto on sunday. Truck only has 102,000 mi on it with
3" suspention lift and 33" cooper stt's with another set of 31" all terains. And it is currently not wanting to start. Within the last 12,000 mi it has had the head gasket done, heads rebuilt, all timing components done, and the water pump. Within the last 1500 mi the plugs, wires, distributor, cap have been done.
I baught the truck downstate MI and drove it home (about 3 hrs mixed highway and non highway) I had stopped several times since i picked it up and shut the truck off/turned it back on and no problems. I parked it that night and went to start it the next morning and it wownt fire up (it was also about 20 degrees in the morning and has been for the last few days) it was a bit warmer (somewhere around 37 when i baught it and drove it home). I did take it down some trails that night and got into a couple decent sized puddles but nothing rediculous. Engine compartment seems dry.
I checked the spark and that seems fine, (as it should be since the parts are new), air filter is dry and clean, when i turn the key on i can hear the fuel pump clicking (kinda sounds like a blinker) and its not "humming". I changed the fuel filter thinking it might be clogged but that didnt help at all. Fuses all are good and not blown.
The truck does have an arctic start 600r remote starter installed by the PO and im wondering if that is messing with it.
ANY ideas would really be appreciated as it is just sitting in my girlfiends driveway in the way of other vehicles
Thanks
01-15-2013, 11:26 PM
forgot to add that it turns over fine when trying to start, just doesnt want to fire up
01-15-2013, 11:51 PM
Real Name: Mat
Real Name: Mat
does it spit and sputter when turning over? try cracking the plenum on the side of the side of the motor towards the top, the big bolt in this picture, after you crack it, have someone turn it over and see if fuel is squirting out. If it doesn't squirt out, it might be your fuel pump. If not the fuel pump then it might be the EFI fuse.
first pic and up and to the left where the bolt is with a black plug coming out of it.
4 runner 3.0 fuel injector replacement - YotaTech Forums
01-16-2013, 04:22 AM
Crack the fuel line to see if there is any fuel pressure , or fuel coming through the line. As the other poster mentioned, check or better yet, change the EFI relay(common failure item). You might check for water leaks around the fuse box.
regards
01-16-2013, 04:59 AM
Real Name: Kevin
Real Name: Kevin
Need more info - you hear a click but it won't crank, or it cranks but won't fire up?
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
01-16-2013, 10:31 AM
it will crank over fine but just wownt fire up. when it was running it was running fine no spuddering or hesitation. Also when i changed the fuel filter there was still gas in the lines
01-16-2013, 10:41 AM
also should my fuel pump be "clicking" like that or should i hear a steady "humming" noise coming from it?
01-16-2013, 11:07 AM
Real Name: Kevin
Real Name: Kevin
My fuel pump doesn't click... I'd hit your local auto parts joint and borrow a fuel pressure tester to be sure, but you might have had your pump go bad.
Another test was suggested above, shoot some start fluid into your intake, see if it'll run for a couple seconds off that. That'd point to a fuel issue too.
01-16-2013, 07:28 PM
Check your ground wires!!!! Specifically, check the one in the alternator harness and the one to the left of the battery (looking in from the front).
I know nothing about puddles, these guys have no idea what they are talking about.
Originally Posted by dorton
I wish I had a 2nd gen.
Originally Posted by BucknutBob
I find myself wishing I had waited and picked up a 2nd Gen instead
Originally Posted by KidVermicious
I want to convert my '85 to IFS.
01-16-2013, 07:30 PM
I've wondered this a million times, but I never really hear the fuel pump, despite trying many times.
01-16-2013, 08:55 PM
Moderator
Real Name: The Chosen One
Moderator
Humming noise, not very loud, you'd probably have to put your ear to the tank.
'89 4Runner SR5 - stock
01-18-2013, 01:03 PM
Ok so I pulled the cold start injector and turned the key. No gas coming out so I'm thinking that its my fuel pump.
01-18-2013, 06:32 PM
Open the gas cap and stick a funnel into the tank filler.
Now stick your ear in the funnel and listen while someone else turns the key to the "on" position.
You should hear the pump run for a few seconds before it shuts back off. (due to the engine not running)
1995 4Runner 4x4
3VZ-E, Auto, 2" lift, 33"s on 15x8's, 4:88 gears
01-19-2013, 12:38 AM
Not the EFI relay. Tried that too but now I have a new one so peice of mind. Ill try the funnel trick soon. Any more thaughts that havnt been posted yet?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
