Originally Posted by kpnavarro
I was about to cut them out using a sawzall but i was just worried i was going to mess up the inside of eye on the control arm
Just drill holes, or burn out the bonded rubber portion, then cut the shell with a hack saw. You could use the sawzall for a portion, but I would use a hand saw for the end part. I had to use a chisel on some shells, even after using the saw.
Best of luck, urethane bushings in these trucks are fantastic(no affiliation, just satisfied customer).
regards
