So tons has happened in the last few weeks and I'm super busy with work and finals and everything so I'll probably leave out some stuff but whatever.
First off I have gone on some pretty crazy wheeling trips with
snivilous
that you can read in his 2001 3rd Gen build thread.
I got my KTT bikini top installed and it's awesome. I took my bumper back off to finish it up and re-align it. I cut some slits in the side for an exhaust vent. Should be on this week if my tranny doesn't blow up.
Why would my tranny blow up? I ordered a new bushing and seat from marlincrawler to fix some of the slop in the shifter. Instead of just pulling off the boot and taking out the 4 10mm bolts that hold the shifter in, I undid the 6 12mm bolts that hold the top assembly on. (wasn't following directions I was just learning as I went) So when the assembly is pulled there is a thick rubber seal with 6 washers in the holes where the bolts go. I didn't realize that they were really loose and didn't pay attention when I pulled the rubber seal out. When I went to put it back in, I saw that one of the washers was gone. I couldn't find it anywhere. I was hoping it wasn't there to begin with or fell out somewhere else, but now I am afraid it fell into the tranny. I got a magnet and fished around inside a bit and got nothing. I figured if it had fallen in I would have gotten it with the magnet. So I just got a different washer and put it back together. When I went to put the seat in, I realized it was the wrong one. They sent me a white one instead of a red. I put the old seat back in and put it together. Took it out for a drive and about 10 minutes in either the transmission or engine started to make a horrible noise. Sounded like grinding with an occasional squeak. If I slowly give it gas, neutral or in gear, it will make the noise but sometimes it will be fine. Obviously I assume the washer really did fall in the tranny and that is whats making the noise. That is the only thing I messed with. I'm going to refrain from driving it as much as I can till the right seat comes and I'll pull it apart and look at it again. I don't think it will do much good though. I really don't want to have to pull the whole tranny apart and search.... Any advice would be awesome. I have already looked on KSL for any w56's..
1987 Toyota 4Runner 4x4 SR5 22RE -
My Build
1986 Toyota Pickup 2wd 22R - Daily
