Originally Posted by 89FourRunner
I feel as though people with both 1st gens and 2nd gens find that factory replacement spring packs or coil packs (1st or 2nd gen) usually result in a look that still appears to have rear "Sag". The spacers are probably your best bet. 2" over stock height in the rear usually winds up looking close to level from what I understand.
Here is a pic of the family 4runner:
There is no sag on ours. Specs for suspension:
Front- factory shocks, urethane control arm bushings, new ball joints, Sway-A-Way 25mm torsion bars, factory alignment specs
Rear- Moog springs, factory shocks, urethane bushings
It probably would have been a tad higher if I'd gone with Bilsteins.
regards
