02-28-2013, 11:54 AM
90 runner loud knocking
I've had this runner almost two years. Wasn't in good shape when I bought it, Isn't any better now. I just changed the oil and hours later I'm on my way home when my engine starts knocking. I kept driving for about 15 miles until i finally parked it, with the knocking even louder. It sounds like its coming from the bottom of my engine. I double checked and made sure everything as far as an oil change was tip-top and all seemed was in order except from underneath it looked like i sprung an oil leak. There was hardly any oil left on the dip stick. Im sure my only option is a new engine from what I hear when I start it up.
02-28-2013, 12:46 PM
Real Name: Caleb
Real Name: Caleb
What engine transmission?
The 3.0s are known sludge builders. What kind of oil are you running?
Got a video or sound clip of the noise?
Find the source of the oil leak, and it will bring you closer to a solution. My guess is something sprang an oil leak, and if your run an engine with no oil, youre gonna have a bad day. I think you would notice if you threw a rod..
Good luck super trooper!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
02-28-2013, 03:25 PM
Real Name: Jerry Reed
Wheres the sound coming from?
Could be a bad rod bearing...
03-01-2013, 01:50 AM
It's an automatic, been running with 5w-30.I don't think I've thrown a rod yet but the knocking is coming from the back of the bottom of my engine. When I was driving it I could really feel the knocking in the pedal when I would accelerate.
03-01-2013, 11:47 AM
Real Name: Kevin
Real Name: Kevin
It could easily be a bolt in the torque converter. Either way, stop driving it unless you want a hole in your block.
Not that I'd know anything about that.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
