Old 03-28-2013, 04:31 PM #1
TX_QtPi TX_QtPi is offline
Real Name: Cynthia
TX_QtPi is on a distinguished road
Real Name: Cynthia
Any Danger in Bypassing the Clutch Switch?
Okay, So for a little bit now the 4runner has not wanted to start unless I press the Clutch Start Cancel Switch.
I know this is NOT how Toyota intended it.
I am suspecting the clutch switch (the one at the bottom of the pedal)
New one, PN 8452035010 is $47.80 +tax.
I read on another thread it's easy to bypass this switch and just not need the clutch to start the truck (Similar to using the CSC)
I'm just wondering if this will hurt the truck in the way it runs or have a negative impact on the transmission?
Any ideas? I don't want to bypass the switch at the cost of having to replace the transmission later on.
Or if you have an idea what else maybe causing please chime in and let me know.
Thanks,
Cynthia
TX_QtPi is offline   Reply With QuoteReply With Quote
Old 03-28-2013, 05:16 PM #2
SparkEE SparkEE is offline
SparkEE is on a distinguished road
I had the same problem. I bypassed the CSC switch almost 10 years ago. It is purely an electrical thing, no direct impact on the trans. With that said, you have to make sure you press the clutch in and / or put the trans in neutral when you start. If you dont, it will still crank. The starter has enough oomph to roll through the parking brake - trust me on that one...
1999 LTD, E-Locker, 265/75/16 Cooper Discoverer ATPs, Bilstein 4600 HDs, '99 tall / OME 906
1987 Pickup, 22r w/ EFI, 298k and still tickin. Can't kill this thing
SparkEE is offline   Reply With QuoteReply With Quote
Old 03-28-2013, 05:44 PM #3
Real Name: Cynthia
Real Name: Cynthia
Awesome!! Thanks for the reply. I'm pretty good about keeping her out of gear but I know it's gonna be one of those oh shoot (edit the oo for an i) moments, LOL.
Sorry for the noob question but I'm so loving My Runner, only had her a couple months so I'm excited!
Old 03-28-2013, 05:54 PM #4
crutchy's Avatar
crutchy crutchy is offline
crutchy is on a distinguished road
crutchy's Avatar
As SparkEE said there are no negatives to this. In fact installing a similar mod like our factory switches is necessary to have a remote start on a manual. It can make for some comical moments if someone activates their starter, either in the car or with a remote when it is in gear.
89 - 3.0 auto on 31s Mostly stock for now
86 - built 22RE 5spd on 35s - Sold
99 - C5 hardtop
crutchy is offline   Reply With QuoteReply With Quote
Old 03-28-2013, 09:21 PM #5
Tanner Tanner is offline
Tanner is on a distinguished road
Lol, I too have started my vehicle ('85 Corolla - doesn't have a CSC switch) when it was in gear and without the clutch; sure was surprised that it was able to over come the parking brake. The guy beside me in the parking lot gave me the: "what the hell was that?" look.
'86 Celica GT-S - Sold
'90 4Runner V6 5spd - Sold
'85 + '87 Corolla GT-S (AE86) - Sold
'85 4Runner 22RE 5spd - Sold
'82 Land Cruiser BJ42 - Current DD
Tanner is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 07:24 PM #6
BrazilianT4R's Avatar
BrazilianT4R BrazilianT4R is offline
BrazilianT4R is on a distinguished road
One reason I see for not doing it is if you have kids. I see this working the same way as the auto transmission not shifting into drive from park if you don't step on the brake.
I think it doubles as a "Kids safety feature".
Current: Red Fox
1994 2.4 22RE M/T Toyota Hilux SW4 (a.k.a. 4Runner SR5), 235/75/R15 Dunlop Grandtrek AT3, running totally stock.
Previous: Black Panther
1997 3.4 V6 A/T 4x4 Toyota Hilux SW4 (a.k.a. 4Runner SR5)
Procomp ES6000 front, ES9000 rear, 265/75/R16 Nexen Roadian AT2 on 2010 Hilux SRV wheels.
BrazilianT4R is offline   Reply With QuoteReply With Quote
Old 04-03-2013, 02:32 AM #7
4runjunkie 4runjunkie is offline
4runjunkie is on a distinguished road
You may have already looked into this, but check out the bracket that holds your clutch pedal in place and make sure its not cracked and warping when you engage the clutch. When I bought my 4runner, the PO told me I had to press the clutch engage button to start the truck. It turns out the bracket was broken so the pedal wasnt following its 'usual' path when engaging the clutch, and therefore wasnt properly hitting the clutch switch. When I replaced the bracket, the clutch switch problems went away.
4runjunkie is offline   Reply With QuoteReply With Quote
Old 04-03-2013, 01:37 PM #8
Real Name: Cynthia
Real Name: Cynthia
Thanks for that one 4runjunkie. I had just replaced the bracket and everything was newly lined up and working correctly. even replaced the little rubber pads that depress the switches.
But it's been by-passed and everything is working fine now.
Thanks to all for the input.
Cynthia
Old 04-03-2013, 06:15 PM #9
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Clutch Safety Switch is pointless to me
I (me myself) find the clutch safety switch pointless.
I park the truck in first gear. When I start the truck, I always put it in neutral to start and and leave it there for several seconds to warm up before I put it in gear. Leaving it in gear, and depressing clutch pedal to start and warm up is unnecessary pressure on system. After all I often end up reversing out of parking spot.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 04-04-2013, 04:04 AM #10
BURNINGAIR's Avatar
BURNINGAIR BURNINGAIR is offline
BURNINGAIR is on a distinguished road
BURNINGAIR's Avatar
Ditch it!
I took mine out simply so I can use the starter alone to get me out of sticky situations on the trail. Broke a fuel line so it wouldnt fire up while I was on some nasty boulders: got it to a flat surface so I could fix it easily and not be in the way holding up traffic.
84 4runner, 37's, about 6\" lift, lockers F/R, 5.29's, 22r
03 Grand Cherokee
02 Jetta 1.8T
BURNINGAIR is offline   Reply With QuoteReply With Quote
Old 04-04-2013, 01:48 PM #11
85toy4runner 85toy4runner is offline
85toy4runner is on a distinguished road
you had one on your 84 , my 85 doesn't have one, well maybe the PO took it out ,I dont know
85toy4runner is offline   Reply With QuoteReply With Quote
Clutch Start Cancel Switch WMDESIGNS 3rd gen T4Rs 5 12-27-2011 05:17 PM
Clutch start switch NathanOfSeattle 3rd gen T4Rs 27 04-22-2011 05:30 PM
1st gen clutch cancel switch HAHA Bad_Vision Classic T4Rs 16 01-16-2011 04:19 PM
Clutch Start Cancel Switch. How does it work? Shoke 3rd gen T4Rs 4 09-11-2009 06:51 PM
When to use the clutch cancel switch? RockyMtRunner Off-Roading 5 07-12-2006 02:22 PM
