04-11-2013, 12:11 PM
#16
Real Name: Kevin
Real Name: Kevin
It's either the starter relay or the starter solenoid itself. Some reading for you: Final fix for intermittent no-crank on the 22re.
Short story - turn the key to on, just before the crank position. Use a wire to jump your positive battery stud straight to the stud on the starter solenoid. If this starts your truck, then a) if your truck doesn't have a factory starter relay, do the fix I detailed in that thread, or b) if it does have a factory relay, follow the link to RADs fix.
If jumping the battery to the solenoid doesn't start the truck, then it's not a wiring issue, it'll be trouble in the solenoid or starter itself. Probably the solenoid, which can be rebuilt for just a couple bucks.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
04-11-2013, 12:20 PM
#17
Real Name: Aram
Real Name: Aram
Thank you so much KidV!! I'm gonna try this and see what happens! I really appreciate it!!
2000 Toyota 4Runner 4 Cylinder 2.7L 2WD on 31x10.50x15s Build thread --> http://www.toyota-4runner.org/3rd-ge...ld-thread.html SOLD!!
1989 Toyota 4Runner 22RE 2.4L 4WD on 31x10.50x15s Build Thread --> http://www.toyota-4runner.org/classi...ml#post1348761
04-11-2013, 12:59 PM
#18
I'm sure you already checked this but make sure your battery did not die. You said you did not turn the truck all the way off and pulled the key out. This could left the radio on until the battery died. Good luck
04-11-2013, 01:19 PM
#19
Real Name: Aram
Real Name: Aram
Actually I havent checked that yet. Now that my dad is back from work with my 3rd gen (he likes driving it better then his nissan frontier ) im gonna go jump it and see what happens. I hope to god its the battery because I dont feel like doing so much work on it lol. Thanks man!
04-11-2013, 01:32 PM
#20
Real Name: Aram
Real Name: Aram
WOOOHOOOOO after a few trys it started back up with a jump!! Thanks guys I really really appreciate yals input! Thats one less thing I have to worry about lol.
04-11-2013, 01:35 PM
#21
Real Name: Kevin
Real Name: Kevin
Or, uh, yeah, it could be the battery.
04-11-2013, 01:41 PM
#22
Real Name: Aram
Real Name: Aram
hey man you were very helpful, at least now I know what threads to look for if I ever do have starting problems, thanks!
04-11-2013, 01:46 PM
#23
Real Name: Kevin
Real Name: Kevin
Simple stuff first. That one bites me in the ass all the time.
04-11-2013, 04:35 PM
#25
Real Name: Aram
Real Name: Aram
Ok fellas I was looking at my runner and I saw these. I know very little about them to be honest. All I know is they are good to have lol. If someone could shed some info on this for me I'd greatly appreciate it. What is their purpose? when should I lock them and unlock them? thanks!
04-11-2013, 08:38 PM
#26
Those are your manual locking hubs for your 4wd system. You should lock them before engaging 4wd and then unlock them before getting back out onto the road to drive any considerable distance in 2wd. It is however okay to leave them in the lock position when going between 2wd and 4wd on the trail. These differ from most modern light duty trucks and SUVs that have automatic hubs. In my opinion (any most off road guys/if not all) manual hubs are better than automatic locking hubs. Just be mindful that when you lock the front hubs and are in 4wd you will not want to have your wheels cranked all the way to one side or another while moving.
89 - 3.0 auto on 31s Mostly stock for now
86 - built 22RE 5spd on 35s - Sold
99 - C5 hardtop
04-11-2013, 08:41 PM
#27
This is designed for you to manually select whether you want your hub to free wheel (dis-engaged from drive axle) or lock (engaged with drive axle).
Covered in user's manual but, only lock IF you want to use 4WD (4Lo or 4Hi). Don't forget to unlock when not needing 4WD. Otherwise your drive axles will spin with the hubs/wheels, causing too much drag, unnecessary wear on axle and also your CV joint & boots.
BTW, in case you have another starting issue, this this Special Service Tool Helps diagnose whether problem is from solenoid and downstream or from the solenoid control wire and upstream.
I a pinch, would also help you start even without an assistant.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
04-11-2013, 08:44 PM
#28
Originally Posted by crutchy
Those are your manual locking hubs... In my opinion (any most off road guys/if not all) manual hubs are better than automatic locking hubs...
Yep! If Landruisers had this, the day-to-day gas mileage would surely improve.
04-18-2013, 12:29 AM
#30
Real Name: Aram
Real Name: Aram
Guys I have a question regarding my manual locking hubs. When I go change a wheel or just wanna take the tire off, will the tire come off if I just take off the bolts like normal or do I have to take off the bolts for that as well?
