Old 03-24-2015, 08:38 AM #46
bump530's Avatar
bump530 bump530 is offline
bump530 is on a distinguished road
bump530's Avatar
I finally had a little time this weekend to work on it.
I built a gauge panel. Im still waiting for my trans temp gauge to come in. Im not planning go running a head unit, just using my phone or mp3 player directly to an amp.
I got my power steering lines and cooler installed.
I got a few other little things done also that really are worth mentioning lol. I plan to start this thing up Easter weekend, if not before.
'90 Vortec 4.3Runner
bump530 is offline   Reply With QuoteReply With Quote
Old 03-24-2015, 08:48 AM #47
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 will become famous soon enough
Hyde802's Avatar
Real Name: Caleb
Getting close!
92 ExtraCab on 38s: built for go, not for show
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 10:21 AM #48
88Toy's Avatar
88Toy 88Toy is offline
88Toy is on a distinguished road
MY GARAGE
88Toy's Avatar
MY GARAGE
Nice work! What will you do for front shock mounts? Keep an eye out for frame cracks around the engine mounts, That frame web isn't as substantial there as one would think.
'88 Truck, properly built
'89 4Runner, build in the planning stage
88Toy is offline   Reply With QuoteReply With Quote
Old 03-25-2015, 01:55 PM #49
bump530's Avatar
bump530's Avatar
Thanks. Yea I wish I would have plated the engine mounts. Ive seen several ppl not plate it and be fine tho. I will be keeping a close eye on it.
As for shock mounts, I will be using the TG shook hoops. I do plan to plate them tho.
Old 03-30-2015, 02:06 PM #50
bump530's Avatar
bump530's Avatar
Well I spent a little time out in the shop this weekend, and this happened:
Don't mind the vibrating noise. That's the gopro vibrating on the battery.
Old 03-30-2015, 02:19 PM #51
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Thats sounds great!
IG: rattlewagon
Old 03-30-2015, 02:34 PM #52
bump530's Avatar
bump530's Avatar
Originally Posted by Hyde802 View Post
Thats sounds great!
Thanks. It was definitely music to my ears lol. I just went back and looked. I drove the 4runner into the shop on 4/1/14 to start pulling the 3.slo. Almost a year later, its finally is making noise again.
Now its time to get this thing drivable.
Old 04-01-2015, 08:36 AM #53
bump530's Avatar
bump530's Avatar
Well Im getting a random misfire code. So I checked the headers with a temp gun and the #3 is a lot colder than the rest. I pulled the plug and it don't seem to be getting fuel. After doing a little research and looking at things on the truck, Im starting to think the spider injection system is having issues. I need to do a little more reading on how to exactly determine if that's the cause tho. If it is, then Im going to keep working on getting it drivable then I will change the injection system.
Old 04-01-2015, 09:00 AM #54
ajohnson's Avatar
ajohnson ajohnson is offline
ajohnson will become famous soon enough
ajohnson's Avatar
Nice work
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
ajohnson is offline   Reply With QuoteReply With Quote
Old 04-01-2015, 12:29 PM #55
bump530's Avatar
bump530's Avatar
Originally Posted by ajohnson View Post
Nice work
Thanks.
Old 04-05-2015, 10:58 PM #56
bump530's Avatar
bump530's Avatar
Well I managed to pull the wiring harness out and get the braided loom mostly installed. I need to pick up some more tape to finish it up.
I ordered the majority of the parts to do the rear disk swap. Brakes will probably be the next thing I tackle.
Old 04-10-2015, 11:15 AM #57
bump530's Avatar
bump530's Avatar
Well I finished up the harness and installed it back in the 4runner. I decided to fire it up again to see if I could figure out what was wrong with my new oil pressure gauge. After it started, I noticed it seemed to be running a lot smoother than before. I check all the header tubes with a heat gun and sure enough, it was firing on all cylinders. Im not sure what the problem was before, but as of now its gone. Hopefully it doesn't come back.
Now its time to get this rear axle setup and the brakes installed. Maybe Ill be able to drive it around the yard in a few weeks.
Old 04-14-2015, 08:52 AM #58
bump530's Avatar
bump530's Avatar
Heres a couple more pics of the loom...
I started on the rear disk brake conversion. Im using Isuzu Rodeo calipers and Montero sport rotors. Ive read that the rotors worked with no mods, but I had to drill the wheel studs holes out to 9/16" for them to slip all the way over the shoulder on the studs. I have the templates made for the brackets. Im going over to a guys house this evening to cut them out since my torch is out of commission at the moment.
Seeing as how I had to remove the hood latch to fit my trans cooler, here are my new hoods pins...
I also figured out the problem with my oil pressure gauge...I had the sending unit hooked up wrong. With the way its mounted, I could really read which of the two plugs was the correct one. I hooked it up according to what I thought the instructions told me, but apparently I was wrong. I swapped the plug and it worked fine.
Old 05-29-2015, 09:42 AM #59
bump530's Avatar
bump530's Avatar
Time for an update...
Finished up the rear brakes
Installed a proportioning valve for the rear brakes
Built an intake out of 3" PVC
I found out the used 4.88 3rd member I bought wasn't in as good of shape as the pics the guy sent me before he shipped it, so I decided to rebuild it. So far Ive tore it down, installed the Spartan locker, and put new carrier bearings. I still need to get a bearing splitter to get the pinion bearing off tho. I plan to to do that pretty soon.
I installed my hood pins. Unfortunately I couldn't used the poly bushings. So I built some stainless plates to rivet to the hood.
I built a new rear driveshaft. We installed the CV joint off the front driveshaft on the rear driveshaft.
After I bolted the driveshaft in, this happened...
Now its time to finish up the little items and get this thing streetable.
Old 05-29-2015, 12:18 PM #60
jgilk1 jgilk1 is offline
jgilk1 is on a distinguished road
That vidwo looks like so much fun!
92 4 runner v6 auto on bfg at/ko 33*12.5/15
Moog+ 1.25", thermo quiet, brembo rotors, rancho 5k rear, rancho 9k front, blazer driving lights, skyjacker stabilizer
jgilk1 is offline   Reply With QuoteReply With Quote
WTB: 1996-1997 Stock(extra long before recall) 4runner bump stops JayRolla Want to Buy/Trade 0 03-15-2012 12:34 PM
'Bump' at a stop? iLLWiLL General Discussions 11 04-12-2009 12:34 AM
&*#$(&(@!!! Bump Bump! 4Runner1371 4th Gen T4Rs 3 12-16-2007 03:26 PM
Bump? nauticalniremor Off Topic 2 08-12-2006 11:20 PM
Fishtail after bump vegascoop Problems & Warranty Issues 2 08-30-2005 09:14 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
