Old 09-18-2019, 02:45 PM #121
bump530's Avatar
bump530 bump530 is offline
bump530 is on a distinguished road
bump530's Avatar
No progress on the 4runner has been made lol. I did pick up top shift tcase the other day. It was a good enough deal (for around my area) to pick up incase I decide to dual case this thing one day. My twin stick I just installed would be a waste then lol.
Ive been working hard to get the shop done. Getting close to being able to work out of it.
Untitled
'90 Vortec 4.3Runner
bump530 is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 01:44 PM #122
bump530's Avatar
bump530's Avatar
Finally did something to the 4R. Installed a set of LEDs and relay harness. I will get them adjusted tonite to try to avoid blinding ppl lol.
Untitled
Untitled
Untitled
Old 03-18-2020, 05:14 PM #123
bump530's Avatar
bump530's Avatar
Few small updates....
Torn down a very rusty (outside only) elocker to clean up and regear to 5.29s. Just needs some black paint and gears setup now.
Untitled
Untitled
Untitled
Picked up some Battle Born beadlocks, some 37" Gladiators, and had the rings powdercoated. They were supposed to be red but turned out more redish orange
Untitled
Untitled
Got the 4runner cleaned up yesterday. Its ready to bring in the shop for work.
Untitled
Hopefully progress will start to flow on this thing. Got a lot of work to do.
Old 03-25-2020, 10:49 AM #124
bump530's Avatar
bump530's Avatar
4runner is in the shop and work has started....
Untitled
Untitled
You can see my surplus center ram Im going to run for hydro-assist. I cut one end off and added a heim joint.
Untitled
Untitled
Started modifying the house for the e-locker. Just a fine tuning on the welds and then ill start cutting and drilling
Untitled
Untitled
Built a mount for my engine to hold the 3rds during rebuild
Untitled
Old 04-08-2020, 09:15 AM #125
bump530's Avatar
bump530's Avatar
Ive been jumping around on the 4runner. I got the e-locker to fit in the housing, but never drilled the holes for the new studs. I then jumped on getting the mounts for the hydro-assist figured out. Then before final welding, I start tackling the mounts for the new trans cooler and steering reservoir lol.
Hydro-Assist ram mocked up.
Untitled
New trans cooler and PS reservoir
Untitled
I also built a fan shroud for the trans cooler.
Untitled
Untitled
Old 04-10-2020, 08:41 AM #126
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Looking good man! Nice work with that e locker.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 02:19 PM #127
bump530's Avatar
bump530's Avatar
Thanks. Im ready to get it back on the road.
Old 07-07-2020, 03:09 PM #128
bump530's Avatar
bump530's Avatar
Finally got it back on the road. Still a few loose ends to tie up, but its drivable.
I put some TG chromoly shafts and wheel bearing nuts on while I had it apart. I also installed some FROR ARP knuckle studs to help with the forces from the hydroassist.
Untitled by bump530, on Flickr
Front axle installed
Locker harness and switches
I changed the fuel pump just mainly because I wanted to change the rubber hose inside the tank. While I had the tank out, I made an access panel so I don't have to drop the tank again to change pump.
Heres how it sits now. Drives way better with radial tires (first time since I built it) and selectable lockers. Just got it together last night, so im still breaking in the gears. Ready to really try it out.
Still need to mount the new radiator overflow. I also just ordered new ujoints for the rear driveshaft and rear wheel bearings. They didn't feel the best when I was putting it back together, so they will get changed soon. After that, Im planning on building some sliders and getting the AC working.
WTB: 1996-1997 Stock(extra long before recall) 4runner bump stops JayRolla Want to Buy/Trade 0 03-15-2012 12:34 PM
'Bump' at a stop? iLLWiLL General Discussions 11 04-12-2009 12:34 AM
&*#$(&(@!!! Bump Bump! 4Runner1371 4th Gen T4Rs 3 12-16-2007 03:26 PM
Bump? nauticalniremor Off Topic 2 08-12-2006 11:20 PM
Fishtail after bump vegascoop Problems & Warranty Issues 2 08-30-2005 09:14 PM
