Old 03-02-2018, 03:55 AM #1
pinagel's Avatar
pinagel pinagel is offline
Real Name: Pat
pinagel is on a distinguished road
pinagel's Avatar
Real Name: Pat
3vze rebuild in process
Hello,
Im currently rebuilding the engine, i bought a junk yard engine because my other one needed some serious machine work to get going again, plus an overhall of the pistons plus crankbearings etc.
Right now im trying to figure out how to pin the ac compressor bracket into the engine. Does it bolt onto the same bolt hole as the engine bracket, the reason im confused is because the bolt i got from my old engine is not deep enough to thread into position, but it seems to be the only logical way to put the bracket on.
Anyways, any help would be GREATLY appreciated.
Leaving on a 14 day trip tomorrow im sure my roommates are happy about the state of the garage. Haha.
3vze rebuild in process-img_2033-jpg  3vze rebuild in process-img_2041-jpg  3vze rebuild in process-img_2042-jpg  3vze rebuild in process-img_1998-jpg
pinagel is offline   Reply With QuoteReply With Quote
Old 03-02-2018, 04:17 AM #2
pinagel's Avatar
Real Name: Pat
pinagel's Avatar
Real Name: Pat
More pictures of where it attaches too.
3vze rebuild in process-img_2050-jpg  3vze rebuild in process-img_2051-jpg  3vze rebuild in process-img_2053-jpg
Old 03-03-2018, 02:03 AM #3
mholme's Avatar
mholme mholme is offline
mholme is on a distinguished road
mholme's Avatar
I just replaced my compressor so maybe these pictures will help. There’s 3 bolts on the side of the block, one of which also holds the main ground strap behind the compressor bracket bolt, and two at the front of the block. The easiest thing to do in your case is probably to line up the two front bolts and then the other three will be lined up. Keep in mind that they are different length bolts for some of the holes.
3vze rebuild in process-92012870-aa40-4aa5-888e-c6f9ed5109cb-jpg  3vze rebuild in process-dc7726c5-6e7d-436b-b107-a57ca8fd3458-jpg  3vze rebuild in process-296345fe-0839-4254-aab0-b7752f28be68-jpg  3vze rebuild in process-9a2d0631-3083-4ba2-9559-0e23041e5748-jpg  3vze rebuild in process-dab0ad42-7df8-4694-845b-ae789845e2e3-jpg
mholme is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 02:04 PM #4
Vokeyz Vokeyz is offline
Real Name: Zak
Vokeyz is on a distinguished road
Real Name: Zak
Wish I could be of more help, but good luck with the rebuild. I was trying to decide to do this to my old 4runner but I felt it was more cost effective to get another truck and start from that platform.
All the best.
Vokeyz is offline   Reply With QuoteReply With Quote
Old 03-20-2018, 04:23 PM #5
cruss062 cruss062 is offline
cruss062 is on a distinguished road
Does anyone have any pictures of the 5vze wiring harness going into a 3.0 94 4runner?
I am struggling with the transmission connectors. I am using a 94 4wd 3.0 4runner and putting in a 98 3.4 5vze and 5vze ecu and wiring harness. I have read all the builds but cant find a diagram or pic of the harness up to the transmission.
cruss062 is offline   Reply With QuoteReply With Quote
Old 03-20-2018, 07:31 PM #6
SomeInternetNobody's Avatar
SomeInternetNobody SomeInternetNobody is offline
SomeInternetNobody is on a distinguished road
Just a word of warning: if you didn't already know, the block and upper half differ from 90-92 and 93-95. If your's is older, the rebuild will go differently.
SomeInternetNobody is offline   Reply With QuoteReply With Quote
Old 03-21-2018, 12:32 PM #7
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Are you talking hydraulic chain tensioner on ppst 92 3VZ-E's? What else upper & lower?
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 02:17 AM #8
4Stammer 4Stammer is offline
4Stammer is on a distinguished road
Sorry to resurrect an old thread - I just purchased a '95 4Runner for my son. It's a project - the guy we bought it from tore the cylinder heads off and then quit on the repair. We got the short block out and it's at the machine shop now. To the point, my question is how easy is it to put that motor back in as a fully dressed long block with the back cross over exhaust pipe in the way? I could put it back together in the order we took it apart but I would rather assemble as much of it as I can on the engine stand and drop it back in. That cross over exhaust pipe look to make it precarious to get those top bell housing bolts back in. Looking to experienced 3VZE users for guidance - thanks!
4Stammer is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 05:31 PM #9
ATGParker ATGParker is offline
ATGParker is on a distinguished road
DT header Upgrade
Pitch the OEM exhaust and put a Doug Thorley Header on it. That is what I did and it makes the assembly much easier when it is bellhousing to engine joining time.
ATGParker is offline   Reply With QuoteReply With Quote
3VZE rebuild project LedFloyd900 Classic T4Rs 12 02-28-2018 07:07 AM
3VZE rebuild kits SasquatchRevenge General Discussions 0 10-19-2015 04:48 PM
5vzfe rebuild process/reccommendations zgensler31 3rd gen T4Rs 28 09-13-2015 03:01 PM
3VZE Fuel Pump replacement(in process), pics 77'911 Classic T4Rs 10 06-15-2013 11:01 AM
In process: 3VZE fuel injection reseal..... 77'911 Classic T4Rs 4 04-25-2010 05:49 PM
