Originally Posted by luvmy89
the breaker i am showing in the first pic i have checked with a voltmeter, it have no power to it thus no power to the doors. Do you know where the power comes form before it gets to the yellow breaker in pic 1
They ran the power circuits for the windows rather weird in these days. You'll need to pull the switch, and check the circuit. It should run a constant loop. If no power to the door harness, you'll need to run the check back to the ignition switch.
One problem with this system, the way it's wired, if one circuit fails in the motors(or harness) it will kill off half of(or most) of the system. These trucks were really not meant for power windows. The system is a bit of an after thought.
regards
