Old 04-27-2013, 11:34 PM #1
mark808's Avatar
mark808 mark808 is offline
mark808 is on a distinguished road
mark808's Avatar
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings???
OK this is a serious undertaking for me the ball joints upper and lower not such a big deal. What will I need to replace these bushings up to metric sizes in sockets and all other tools, etc. Pictures would help and I am going to try and do the rear myself as well, or am I over my head? If I can do all this and do it right thast is my main concern then perhaps I can pick the proper suspension lift and install myself? Thanks to everyone for all of your help much respect.
mark808 is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 12:37 AM #2
Iroke17 Iroke17 is offline
Iroke17 is on a distinguished road
If your gona pull the a arms might as well lift it
84' Honda Interceptor 1000 -=|=- 86' 4runner 22re (7mge soon) -=|=- 85' 4runner Shell for sale -=|=- 87' MR2 MK1 4age
Iroke17 is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 01:15 AM #3
EagleFire EagleFire is offline
EagleFire is on a distinguished road
Les Schwab also does this job as well. They quoted me on the west coast about 385 for front left and right Upper Control arms. I have heard the main pain point is just getting the bushings out but if you want to do it yourself see if you just can't find a shop with a machine press to do it for you.
EagleFire is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 11:28 AM #4
77'911 77'911 is offline
77'911 is on a distinguished road
I posted pics and did this task a few years back. I'd start with the rear suspension first for the rebuild. Then , work your way up to the front. Once the front a-frames are rebuilt, it will need a proper alignment. Here are some of the parts on my suspension rebuild:
1) Sway-a-way Torsion bars 25mm
2) new Toyota Torsion bar adjusting hardware, Olathe Toyota Parts Dept(online)
3) Complete Urethane bushing Kit, suspension.com
4) MOOG rear coil springs
5) factory shocks, toyota
6) Ball Joints (NPN, japan made)
7) Wurth copper anti-seize and Mobil 1 synthetic marine grease for urethane bushings
regards
77'911 is offline   Reply With QuoteReply With Quote
Old 04-28-2013, 11:43 AM #5
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Yeah, no. A vehicle should never be modified "just because". The OP should lift his truck if he needs or even wants to lift it, but it should be a researched decision, not for the hell of it. That's how trucks get screwed up.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 05-01-2013, 10:25 AM #6
i was assuming he would know what hes doing if hes removing arms...
Old 06-27-2013, 01:00 PM #7
mark808's Avatar
mark808's Avatar
I know I can do the job I just have never done this and know that it will be a serious job to get it done 1 person without all the help of a modern garage and going solo. I do want and need the suspension lift. Has anyone heard any info on tuf country susp. lifts, good or bad?
Old 07-03-2013, 12:46 PM #8
azshtr azshtr is offline
azshtr is on a distinguished road
I found that buying the upper control arms new, with ball joints and bushings already installed, was almost the same price as the parts alone (ball joints and bushings alone). That way I also had no need to mess with replacing the bushings, just unbolt old, instal new, get alignment.
1991 2nd Gen build in progress
azshtr is offline   Reply With QuoteReply With Quote
Old 07-03-2013, 12:56 PM #9
Border4Runner's Avatar
Border4Runner Border4Runner is offline
Real Name: T.J.
Border4Runner is on a distinguished road
Real Name: T.J.
Azshtr, where did you find those complete assym's at?
94' SR5 3.0L 4x4 a/t (2nd gen)
11' Polaris RZR 800s
Border4Runner is offline   Reply With QuoteReply With Quote
Old 07-03-2013, 04:05 PM #10
Control arms at Rock Auto are 109 each with bushings and balljoints. Ready to bolt on. The Bushing and ball joints add up to $75
Old 07-04-2013, 01:57 PM #11
ToyoTech's Avatar
ToyoTech ToyoTech is offline
ToyoTech is on a distinguished road
ToyoTech's Avatar
from the little research i did when i was gonna do mine. most if not everyone had to torch the old bushing out. it was too much work and money so i just brought a Blazeland LT kit that comes with upper and lower arms with new poly bushings
ToyoTech is offline   Reply With QuoteReply With Quote
Old 07-04-2013, 02:32 PM #12
I don't like poly bushings for off road. They don't have the same flex as rubber and give a harsher ride. Granted that might be great for a street car but when rough stuff is concerned give me rubber, even if they do wear out faster. That's of course just my opinion for the sake of open dialog and is up for debate.
Old 07-04-2013, 05:03 PM #13
Greg_Canada Greg_Canada is offline
Greg_Canada is on a distinguished road
Upper control arms only. and the ball joint... you don't want the mevotech, they're crap. I'd like to choose which balljoint i want to use, as there are huge quality differences.
That is to install energy poly bushings. If you want stock bushings, rockauto sells them and you have to press the old ones out and the new ones in. My local mechanic charged me $20 to do this, took them a few minutes.
Poly lasts longer and is smoother, it's not going to be a massive difference, just a more solid feel on the road.
IMHO the biggest PIA's in changing the bushings, is making sure the adjusting bolts aren't seized (then you have to cut them out) and the torsion bar bolts may also be seized. Everything else is straightforward. When i did mine, i replaced / rebuilt everything. See my build thread here... Southern Ontario Toyota Trucks ? View topic - My 89' 4runner
Greg_Canada is offline   Reply With QuoteReply With Quote
Old 07-04-2013, 07:35 PM #14
Freb_mc's Avatar
Freb_mc Freb_mc is offline
Freb_mc is on a distinguished road
Freb_mc's Avatar
I work at advance auto and we "rent" a tool that makes this job alot easier, yeah it costs $89 but you get it back when the tool is returned. Deposit I guess is more accurate. Takes awhile if its your first attempt but you save some money over paying a garage to do it.
Freb_mc is offline   Reply With QuoteReply With Quote
Old 07-04-2013, 09:48 PM #15
Originally Posted by Greg_Canada View Post
Upper control arms only. and the ball joint... you don't want the mevotech, they're crap. I'd like to choose which balljoint i want to use, as there are huge quality differences.[/url]
I was only quoting uppers as I said in post 10. Mevotech? OK... then go with the raybestos for $111, either will last MANY miles over wore out ones....
Anyone have expreicne replacing upper control arm bushings? One04FourRrunner 4th Gen T4Rs 9 11-24-2013 03:12 PM
Rear Lower Control Arm Bushings Maritimer 3rd gen T4Rs 3 02-11-2012 12:19 PM
Upper control arm bushings wep0520 Classic T4Rs 1 03-22-2011 12:02 AM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
Upper control arm bushings Run 4 est Run Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-29-2010 12:59 PM
