Originally Posted by KidVermicious
Are you sure the wires are put back correctly? Did you maybe blow a fuse or two when you were pulling or installing the alternator?
If the wires and fuses all check out, look for spark. If your spark is good, pull a plug or two and smell for gas. If you have blue spark and and wet spark plugs, then you've lost timing or compression.
But my money is on something you touched while replacing the alternator, spark plug wires or a blown fuse or something.
I did go over the wire placement and according to the diagram I found, I did get them on correctly. (1,3,5 front to back on passenger side, 2,4,6 on drivers, and the distributor cap is labelled, coil was easy to spot of course.)
someone is helping me through pms as well, and came to the same conclusion. AT one point when I was reconnecting everything, I forgot to d/c the battery, and the red wire on the alternator touched metal and sparked.
I pulled the 80A, 40A, and 30A fuses to have them checked, the EFI smaller one looks fine, but should I have it checked as well? Any other fuses I might be missing? Thanks so much for the reply.
