Old 04-02-2021, 06:07 PM #1
4RunnerNorway 4RunnerNorway is offline
4RunnerNorway is on a distinguished road
Bleeding brakesystem after rebuild
Hi!
Im having trouble bleeding out all the air from the brake system. I did a complete rebuild at the rear, but cant get all the air out...
I guess its the load sensing valve causing the problem? no air at the wheels atm...
The pedal is not as responsive and as hard as it should be.
Ive even used vaccum tools.
Is there any way to pressurize the system from the master cylinder? Any suggestions?
4RunnerNorway is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 07:46 AM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Did you bleed the load sensing valve too?
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 10:00 AM #3
Yes, several times
Old 04-06-2021, 11:54 AM #4
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
check for a leak at the master cylinder.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 07:24 AM #5
Forgot to add that I replaced that aswell. No air or leaks there
Old 04-07-2021, 09:13 AM #6
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
And you bench bled the master before you put it on?
You got air in the system somewhere. Are the rear shoes adjusted properly?
IG: rattlewagon
Old 04-08-2021, 08:46 AM #7
Yes. Brakes adjusted properly aswell.
Maybe Ill just leave it to a workshop. They surely have some pro tools for the job...
Old 04-11-2021, 11:35 AM #8
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
what order are you bleeding the brakes in?
furthest to closest?
LR -RR -LSPV-RF -LF
i have used this order for years with great success
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
air , bleeding , cylinder , rebuild , system
Tranny bleeding chompster4runner 4th Gen T4Rs 8 08-20-2016 06:42 PM
CV joint rebuild or not to rebuild, that is the question!!! alia176 4th Gen T4Rs 7 07-19-2016 09:09 PM
abs need bleeding? shahsmerdis 4th Gen T4Rs 1 01-28-2016 02:34 PM
Rebuild my current CV axles or buy used oem and rebuild them? mrwinkle13 4th Gen T4Rs 8 09-16-2015 03:20 PM
Bleeding my brakes oa8888 Maintenance/Detailing 5 12-21-2009 08:15 PM
