06-06-2013, 03:49 PM
Real Name: Don
Real Name: Don
Brake warning light flashes intermittently
OK, so back before my dad gave me is 4runner, he had to change the brake booster. I wasn't around when he swapped the parts out, so I don't know if he might of knocked a wire or something out of place but, the brake warning light on the dash now flashes intermittently.
I have looked under the hood around the booster and haven't seen any loose wires, and I pulled the sensor plug wire on the mastercylinder, jiggled and twisted the wire around and plugged it back in. That didn't fix the problem though. The brake fluid level is topped off, btw.
Does anyone have any ideas of what to maybe look for?
1995 Toyota 4Runner SR5 3.0 V6 5Speed 31" BF Goodrich All-Terrains
Magnaflow Hi-Flow Cat & A Cherry Bomb Glass Pack
06-06-2013, 09:13 PM
Moderator
Real Name: The Chosen One
Moderator
The booster has no wiring and nothing to do with the dash light.
If it's not the fluid level switch in the MC, the other possibility is the switch on the e-brake. Get under the dash and check it out.
It's at the end of the e-brake rod.
'89 4Runner SR5 - stock
06-06-2013, 10:42 PM
Mine flashed when the shift solenoids started going south. Then I got the brake flash with the O/D flash.
06-07-2013, 09:46 AM
Real Name: Cory
Real Name: Cory
The alternator can trigger the brake light too, has the battery light came on?
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
06-07-2013, 02:09 PM
Moderator
Moderator
That's correct, but the Charge light will be on at the same time.
06-08-2013, 12:30 AM
If you're not losing brake fluid then I second the e-brake switch.
'89 4Runner Special Edition, Original Owner
22RE, 5-Spd, SAS, Lockers, Duals
Toyota Fiberglass panels
06-08-2013, 12:31 AM
Real Name: Cory
Real Name: Cory
That's what I meant by battery light. Didn't come to me at the time.
