Originally posted by VTAOFFROADER
how do i flush it out with the radiator off... do i have to start the truck and let it flow out?? u seem to know alot these problems... can you help me out by just tellin me how to do it... please... thanks again... o yea... i got a new radiator coming tomorro... so i should flush it out before i put that one in?? right?? i just need ur advice... thanks again
Here's how I would do it:
Prestone sells flush kits (Wal-Mart, Autozone, O'Reilly's) pretty cheap, which is simply a yellow plastic "Tee" fitting that you install in one of your heater hoses, and has a connector that fits the male end of your typical garden hose.
Just install that "Tee" fitting, connect your garden hose and turn on the water and flush until it keeps coming out clear from the open radiator hoses, turn off the water, let it drain out of the motor, then repeat a couple more times. You can start the engine to make sure the water pump gets flushed out, but no need to leave it running the whole time, and DON'T leave it running when the water is not running.
That should be thorough enough.
