Old 06-18-2013, 04:47 PM #1
kpnavarro kpnavarro is offline
kpnavarro is on a distinguished road
3.0 (3vze) Running hot at freeway speeds
I have a 3.0 3Vze 4Runner and when I am driving at freeway speeds at about 70mph in the desert (95+ degrees outside) it gets hot while driving up hills. especially when you down shift. If I drive slow 40-50mph it doesn't get hot. The transmission is not overheating (no blinking A/T light). No loss of radiator fluid. Recently replaced thermostat and Radiator. Radiator is a Aluma-Plastic from autozone. I don't believe I have a head gasket leak because I have no loss of fluid and no oil in the radiator. I have burped the system again the other day. When I am driving with outside temp of 60-80 degrees its fine. Any Idea of what is wrong? Bad Radiator?
kpnavarro is offline   Reply With QuoteReply With Quote
Old 06-18-2013, 05:03 PM #2
Lab Rat Jason Lab Rat Jason is offline
Lab Rat Jason is on a distinguished road
Test your thermostat by tossing it in a pot of water and boil it. It should open before the water boils. If I does not or if it only opens a little, your thermostat is probably bad. I had this happen to a friend of mine just after he changed his radiator out on a 2nd gen.
Lab Rat Jason is offline   Reply With QuoteReply With Quote
Old 06-18-2013, 05:20 PM #3
I originally had a fail safe thermostat and pulled it and tested it and it was fine but i put a new one in for the hell of it but no change
Old 06-18-2013, 07:37 PM #4
77'911 77'911 is offline
77'911 is on a distinguished road
Check your fan clutch and get a copper/brass Toyota rad for that 3VZE. The typical aftermarket rads are too small and not efficient enough. You might flush the block out while your in there. With the rad removed, I'd also clean, wash out the condenser.
regards
77'911 is offline   Reply With QuoteReply With Quote
Old 06-18-2013, 08:27 PM #5
supkar supkar is offline
supkar is on a distinguished road
95 degrees and going uphill? Sound like a recipe for disaster. Fan clutch, possibly a new rad if clogged and maybe run it with more water, less anti-freeze in the summer. Water cools better. If that does not help, turn on the heat and fan to act as a second rad. Better than a BHG or worse.
supkar is offline   Reply With QuoteReply With Quote
Old 06-19-2013, 01:24 AM #6
The fan clutch is good but I think its just a perfect storm of issues, drove home yesterday and it was 108 outside driving up hill with a 40mph head wind and a steady incline over about 20 miles. I was thinking about buying a full aluminum radiator
Old 06-19-2013, 11:54 AM #7
2ndGen4runner4x4's Avatar
2ndGen4runner4x4 2ndGen4runner4x4 is offline
2ndGen4runner4x4 is on a distinguished road
Check your timing also... but I gotta agree that you should be running a nice fat 3 or 4 core radiator.
1995 4Runner 4x4
3VZ-E, Auto, 2" lift, 33"s on 15x8's, 4:88 gears
2ndGen4runner4x4 is offline   Reply With QuoteReply With Quote
Old 06-19-2013, 12:11 PM #8
Well i guess ill invest in a full aluminum radiator so i dint have to worry about it anymore. I was looking at Champion all aluminum radiators, has anyone tried one out?
Old 06-19-2013, 04:06 PM #9
I agree on the alum rad. Bought a cheapo alum rad for my 87 22RE yearst ago and it never overheated. Then, I put it in my 89, 3.0 as a temp. measure and it kept it plenty cool, even though undersized and without the fan shroud.
Old 06-20-2013, 09:23 PM #10
Does anyone know if you can put radiator for a 1995 3.0 3VZE 4x4 in the 4x2. I am assuming the bolt pattern is slightly different
Old 06-21-2013, 02:50 PM #11
jd20phill jd20phill is offline
jd20phill is on a distinguished road
Radiators are the same, so yes it will fit (as long as it is from an auto too)
jd20phill is offline   Reply With QuoteReply With Quote
Old 06-28-2013, 12:52 AM #12
So I bought a full aluminum radiator from Champion Cooling Systems, dropped right in and fixed my cooling problem, couldnt be happier. Dont but radiators feom autozone they are pieces of junk
Old 06-28-2013, 05:14 PM #13
Zorlac Zorlac is offline
Zorlac is on a distinguished road
Cool!
For my 3.0 built, I did purchase a new radiator (cc50 champion radiator) looks and works fine, did you buy the same one?
VZN61LG-MSEA
UZN106L-PRMRS
GRN215L-GKAZK
Zorlac is offline   Reply With QuoteReply With Quote
Old 06-28-2013, 05:50 PM #14
Yeah I purchased the CC50 from Radiator Galaxy and actually picked it up from the factory since it is close to my house. They were super nice and really helpful, I even had them double check to make sure it fit because it was sold as a radiator for the 4x4 and I have a 4x2. It dropped right in with no problems and works great.
"Surging" from 20ish MPH to Freeway speeds A.Wilson013 3rd gen T4Rs 2 04-30-2011 05:05 PM
91 3VZE into 93 Auto 3VZE Swap 4beginner Classic T4Rs 1 04-13-2011 08:54 AM
Anyone running headers on their 3VZE V6?.... 77'911 Classic T4Rs 0 04-29-2010 01:28 AM
Steering wheel shudder when braking at freeway speeds bju96 3rd gen T4Rs 4 09-09-2009 03:00 AM
hesitation at freeway speeds miknurb 3rd gen T4Rs 2 09-01-2008 11:47 PM
