Old 07-22-2013, 09:36 PM #1
88yota's Avatar
88yota 88yota is offline
Real Name: Michael
88yota is on a distinguished road
88yota's Avatar
Real Name: Michael
Advice on front end rebuild
I recently purchased a 1987 sr5. 4runner. I just ordered bj spacers and 33x10.50 km2's. I have a set of 4.88's that will be going in as we'll. for piece of mind I am planning on putting new ball joints in with the spacers. Both of my cv boots are torn so I was going to pop in new axles while the diff was out. Is there any reason to replace any of the tie rods of idler pitman arms? FYI, there is little to no play in the steering wheel. This will be a DD and family camping rig so I want it to be road worth and dependable
88yota is offline   Reply With QuoteReply With Quote
Old 07-22-2013, 10:55 PM #2
BoatRacer's Avatar
BoatRacer BoatRacer is offline
BoatRacer is on a distinguished road
BoatRacer's Avatar
I tend to overdue things sometimes, but I would recommend replacing them if your already going to have most of the front end apart anyway. Your going to want to have an alignment done after the lift and it would suck to have to pay for another one if you decided to replace the tie rods later on. If not, just inspect them closely and make sure the zerk fittings are good and they get greased every once in a while.
'87 SR5 5-speed 22RE, 4.88's, 33" Coopers, 1.5" bj spacers, rear AAL, V6 brakes, FJ wheels, short throw shifter.
'08 TRD Off Road Taco 6-speed, 37" MT ATZ
www.U11racing.com
BoatRacer is offline   Reply With QuoteReply With Quote
Old 07-23-2013, 03:25 AM #3
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
x2
Consider an Autozone idler and the bronze idler bushings from SDORI. Larger tires tend to kill the idler pretty quick on these trucks.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 07-23-2013, 09:54 AM #4
88yota's Avatar
Real Name: Michael
88yota's Avatar
Real Name: Michael
In looking at cost of the cv axles, is the trouble of just replacing the boot worth the savings in $$? The easiest thing to do is switch out the axle of course, but not the cheapest either.
Old 07-23-2013, 10:45 AM #5
77'911 77'911 is offline
77'911 is on a distinguished road
I rebuilt the front end on our 1990 4runner without doing the tie rod ends, but they were in good shape at the time. The center drag link was also replaced under warranty. I changed out both upper and lower ball joints and installed urethane a-frame bushings. The truck also got Sway-a-Ways 25mm torsion bars and new Toyota adjustment hardware. The result, the truck was much higher (even with a factory alignment) and front end is very tight.
Check the idler, rod ends, drag link, and steering shock(if any), replace if needed. You would be surprised though how bad things get over time. Our suspension was in great need of a rebuild after 70k miles and multiple years.
regards
77'911 is offline   Reply With QuoteReply With Quote
Looking for advice: Rebuild vs Replace Chandler_Ross 3rd gen T4Rs 6 03-30-2013 02:50 PM
Rebuild front-end David Rogers Metal-tech 4x4 1 03-01-2013 06:38 PM
4runner rebuild advice? Vally Boy209 3rd gen T4Rs 2 01-21-2013 02:36 PM
Advice on parts for rebuild. Brand X Classic T4Rs 5 02-08-2010 09:11 PM
Newbie seeking advice on '88 runner 22re rebuild. 4StringSlinger Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-09-2004 01:53 PM
