Just finished installing shift solenoids in my A340 4WD trans. Also decided to drop the pan on the transfer case. Good thing because there was a solenoid with a wire broken off. I soldered the wire and put everything back together. The fluid that came out of the transfer case was the same color and smell as trans fluid. Do I need to fill the transfer case separate from the trans or will the trans fluid flow into the transfer case.
A340what? What year is your truck, what motor does it have? There's an A340H that shares fluid between the transmission and transfer case, and there's an A340F that I think has a separate transfer case that'll need it's own fluid.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
