Originally Posted by ClintR2
Got it all installed.
Not much metal shavings in the pan. Just very fine shavings and like dust.
Truck had more power in the low gears.
However is is reading a code 41. TPS . Changed it and not difference.
Car runs very ruff and idling high. Adjusted the timing and still no difference.
The check engin light is off but still runs very bad.
I am stumped.
Any idea what it could be??
Bad TPS or widening harness??
your throttle could actually be out of position..
4Crawler has a pretty could write up on trouble shooting the TPS
Toyota 22RE Throttle Position Sensor
you made want to try this first though, it is a quick and easy to do.
Before re-adjusting or replacing clean throttle body,reset ECU by disconnecting battery or removing 15 amp EFI fuse for at least 1 minute.
