Old 04-22-2016, 01:51 AM #16
txlonghorn85 txlonghorn85 is offline
txlonghorn85 is on a distinguished road
Good info on the solenoids. I'll be doing this soon on my 85.
txlonghorn85 is offline   Reply With QuoteReply With Quote
Old 04-27-2016, 07:35 PM #17
Down by the Water Down by the Water is offline
Real Name: Andre
Down by the Water is on a distinguished road
Real Name: Andre
it's the thermostat dummy!
Well, I finally talked with a Toyota mechanic. The first thing he suggested was to replace the thermostat. I did and it seems to be driving fine. He explained, if the thermostat isn't working properly it can be keeping the engine to cool. This prevents OD from kicking in (it's a feature, not a bug.)
Lesson learned, start with the cheapest, easiest fix. I had read about this thermostat thing but it just didn't make sense to me at the time. Live and learn.
Down by the Water is offline   Reply With QuoteReply With Quote
Old 07-01-2018, 09:32 AM #18
ClintR2 ClintR2 is offline
ClintR2 is on a distinguished road
Sorry to jack your thread, but trying to get an answer. I have a 1992 4Runner. First gear is there but not much torque or power. All other gears it shifts fine. On the interstate it will run 75-80 mph them come to a hill and will slow down. Ran a diagnostic on it and got a code 14 and O/D wash flashing (code 64).
64 reads bad number 3 solenoid. But sure if it is this or a torque converter.
Has anyone had this problem? If so please let me know.
Thanks
ClintR2 is offline   Reply With QuoteReply With Quote
Old 07-01-2018, 09:46 PM #19
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
You can buy all 3 solenoids on Ebay for $60
https://rover.ebay.com/rover/0/0/0?m...2F281781703567
Or go to the dealer and pay $75 each.
I'd drop the pan and replace the solenoids..problem persists than you know it's the torque converter...if not you know it was a solenoid...which is way easier to replace than dropping the transmission for the t/c
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 07-03-2018, 12:14 AM #20
Bought them! I will check to see if this will fix the problem.
Praying that it does.
Will update when installed.
Thanks
Old 07-07-2018, 02:07 PM #21
Dropzone's Avatar
Dropzone's Avatar
Thanks
@ClintR2 that may have been the incorrect link.
Hoping you double checked it was for the A340H transmission. There are several A340's out there and some sellers don't specify the A340H
@503dropzone on IG
Old 07-07-2018, 11:19 PM #22
@Dropzone
Where exactly can you tell what model transmission you have?
I have a plate in the side of it but does not read like any numbers listed.
Old 07-07-2018, 11:28 PM #23
@Dropzone
It is a A340H. Found on the vim plate in door.
Here is a picture of the solenoid I received.
They read on the box that they work for
A340 E/H/F
https://photos.app.goo.gl/p7MU6xGqpkCnZG4y8
Hopefully they will work
Old 07-08-2018, 10:41 AM #24
Dropzone's Avatar
Dropzone's Avatar
@Dropzone
A340 E/H/F
cool, just wanted to double check
@503dropzone on IG
Old 07-08-2018, 02:12 PM #25
@Dropzone
What Solenoid is what? Location of what solenoid is 1,2 and lockout-- Can not seem to get a straight answer on this.
Old 07-09-2018, 12:29 AM #26
Got it all installed.
Not much metal shavings in the pan. Just very fine shavings and like dust.
Truck had more power in the low gears.
However is is reading a code 41. TPS . Changed it and not difference.
Car runs very ruff and idling high. Adjusted the timing and still no difference.
The check engin light is off but still runs very bad.
I am stumped.
Any idea what it could be??
Bad TPS or widening harness??
Old 07-09-2018, 12:04 PM #27
Dropzone's Avatar
Dropzone's Avatar
I am stumped.
your throttle could actually be out of position..
4Crawler has a pretty could write up on trouble shooting the TPS
Toyota 22RE Throttle Position Sensor
you made want to try this first though, it is a quick and easy to do.
Before re-adjusting or replacing clean throttle body,reset ECU by disconnecting battery or removing 15 amp EFI fuse for at least 1 minute.
@503dropzone on IG
Old 05-27-2020, 09:12 PM #28
steveski34 steveski34 is offline
steveski34 is on a distinguished road
I am having shifting difficulties in my 95 automatic tranny. The engine revs to 4000, mph slows and it won’t shift easily. I think it’s my shift solenoids, been researching the Axiom tech ones. They worked well for you? I’m ho-I gotta it is my shift solenoid
steveski34 is offline   Reply With QuoteReply With Quote
WTB: a340h/f solenoid kit rustbucket Want to Buy/Trade 0 05-20-2012 02:57 PM
4.30's and shift solenoid Alabamaguy Want to Buy/Trade 6 03-22-2012 06:44 PM
A340H A340H Transfer Case Oil Cooler ongoing Classic T4Rs 5 11-06-2011 11:19 AM
CEL Shift Solenoid... Should I buy? bent77 3rd gen T4Rs 4 09-27-2011 02:48 PM
Code P0770-Shift Shift Solenoid E-Please help!! eric70412 3rd gen T4Rs 1 08-16-2010 01:31 AM
