Hey guys! The solenoids were a success! I also replaced the thermostat and it's running as it should and everything seems to be back to normal.
Just as a note, on the 1992 4Runner, you WILL need to drop the sway bar to be able to drop the transmission oil pan. Other models you can get away with it, but the 92' you can't. My sway hasn't been touched probably since it was originally purchased to the bolts were pretty well rusted to the frame.
Anyway, I have this forum to thank for all the help and information I've been gathering about solenoid replacements. I ended up using these:
More Information for ATP RE5 and they fit great in the 92'
Cheers!
