Originally Posted by brocktice
I just kind of wonder what happened to the old bushing. BTW, make sure you use a hard, flat surface to snap it on, and you're totally vertical. It's a tricky little bugger.
Stock bushing is rubbery. It probably just dis-integrated and fell into and got ground into powder by the tranny. (I found mine messed up but still in place)
Yes, Marlin Crawler seat is good. It's plastic, not rubber like stock. Plastic makes better sliding surface against metal half-ball of the shift lever.
Guys, make sure you read remove and replace procedure properly so you don't end up unscrewing the wrong cover plate.
