Old 01-08-2018, 11:14 AM #61
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
in september, i noticed a small coolant leak at the radiator outlet. the radiator was a csf replacement, and all metal. so, i replaced it with another csf all-metal version. it wasn't quite an exact fit, as the core was about a half-inch shorter, so i had to modify the lower area of the shroud to allow it to clear the outlet.
all of the mounting holes lined up, and the factory hoses fit perfect. so, not horrible, but a minor inconvenience when installing. kept the old radiator, so i might take it to a shop to see about repairing it.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 02-21-2019, 08:32 PM #62
wallytoo's Avatar
wallytoo's Avatar
the non-liquid filled gauge failed last month. stuck the old gauge that leaked the glycerin out of it back in place. it works for now. i'll probably try a smaller liquid gauge similar to RAD4r's gauge when this one inevitably permanently fails.
the fuel pump is still working, too. now almost 4 years.
Old 02-22-2019, 10:34 AM #63
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
Nice car and thread
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 09-04-2019, 02:31 PM #64
wallytoo's Avatar
wallytoo's Avatar
an update. very soon after purchasing the 4r, i added a headlight relay in order to preserve the column switch contacts, and that modification has worked very well now for over 5 years. i did eventually take the switch apart to clean the internal contacts, using emery cloth, but the headlight relay has been doing its job. one thing that i didn't like about adding the relay was losing the high beam indicator light on the dashboard. the relay prevents the dash light from picking up enough voltage to light up when the high beams are on, and i had been unable to come up with a solution that would restore the indicator function.
fast-forward to today. i ordered and installed a LED from superbrightleds.com - WLED-CWLX: 194 LED bulb - 1 high power LED - miniature wedge base. annnnd, the high beam indicator works again after 5 years. so, if you have added a relay to your headlights, and want to have a functional high beam indicator on the dash, this works.
Old 09-09-2019, 07:30 PM #65
Heathen_S13 Heathen_S13 is offline
Heathen_S13 is on a distinguished road
Thanks for the detailed thread. This gives me plenty of things to do for when I go pick up my 86 this week!
Heathen_S13 is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 08:09 PM #66
wallytoo's Avatar
wallytoo's Avatar
earlier this year, i picked up some later toyota alloy wheels (the “offset 8” version) that had 32x11.5x15 tires. two tires were junk, but two were good with plenty of tread. i bought two tires from simpletire.com, desert hawks, in the same size for $215 delivered. i’ve put several thousand miles on these larger tires, and they have worked well. no fender rubbing. i do need to downshift a bit more often, but still plenty drivable.
Old 11-03-2019, 07:05 PM #67
wallytoo's Avatar
wallytoo's Avatar
rebuilding the 22re from my other '87 4runner, a white sr5 5-speed, 242K miles. after pulling the engine, it was clear that a previous owner used "stop leak" or similar snake-oil to try to solve/hide a problem. so i decided to rebuild the engine, as it appeared to be in decent condition. had the block and head cleaned and checked for cracks; solid report. so, the block got decked (along with the timing cover and the original toyota head was reused with a new valvetrain/cam installed).
pulling it:
back from the machine shop:
Old 11-03-2019, 07:08 PM #68
wallytoo's Avatar
wallytoo's Avatar
mounted on the stand, ready to start putting things back on it:
bored 40 over (1 mm)
Old 11-03-2019, 07:11 PM #69
wallytoo's Avatar
wallytoo's Avatar
much cleaner than the filthy block when it was removed from the truck
Old 11-03-2019, 07:45 PM #70
wallytoo's Avatar
wallytoo's Avatar
new timing chain set added, although reusing the timing cover.
used a rubber mallet to tap the timing crank sprocket on
Old 11-03-2019, 07:49 PM #71
wallytoo's Avatar
wallytoo's Avatar
aligned the links with the marks on the sprockets
added the new tensioner
and the gaskets
Old 11-03-2019, 07:56 PM #72
wallytoo's Avatar
wallytoo's Avatar
prior to installing the chain components, i tapped the threads with appropriate sized taps to clear and clean the block threads, and used CRC drilling/tapping oil to lubricate the tap. i also purchased a new set of timing cover bolts from 22re performance - a nice kit, and each bolt came in its own bag with a label, along with a diagram showing where each fits on the timing cover. torqued the bolts using torque wrenches. 29 ft-lbs for the 10mm bolts, 109 in-lbs for the 8mm bolts
Old 11-05-2019, 02:53 AM #73
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Originally Posted by wallytoo View Post
rebuilding the 22re from my other '87 4runner...
Sweet work! If you want it done right, do it yourself. I wish I had the room and equipment and lear how to rebuild.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 11:01 AM #74
wallytoo's Avatar
wallytoo's Avatar
chasing the block threads for the headbolts
headgasket and head installed
Old 11-14-2019, 11:07 AM #75
wallytoo's Avatar
wallytoo's Avatar
new valvetrain
oil pump back on
crank pulley and water pump installed
wally world tire fun delucat2 4th Gen T4Rs 18 11-04-2013 09:12 PM
General Upkeep ddoyle General Discussions 2 10-20-2013 09:13 PM
Maintenance and Upkeep ?s for my '96 slampe 3rd gen T4Rs 15 02-08-2011 06:34 PM
Best Upkeep 4runnerndachi 4th Gen T4Rs 3 09-14-2006 09:53 PM
hit and run in wally world parking lot RunnerUp 4th Gen T4Rs 17 08-25-2006 03:54 PM
