Originally Posted by Steven94
Is the motor stuck? If you can, have someone hold the window in place while you move the arm down. Then you can set the window back in the slots. My front passenger window keeps coming off the arm as well. I took a look a it, and it seams that the clamps will no longer hold the window like they should. So I will probably need to glue it in place. You may need to do the same to prevent this from happening again.
Has anyone had success fixing the clamping issues? Any write-ups about it?
