Originally Posted by KidVermicious
... I used a multimeter instead...I should have heard the relay clicking and gotten bouncing voltage, right? I heard no clicking and measured a steady 12.something volts.
Correct, KidV. With a multi-meter, relay should click fast because it is seeing
high resistance of the voltmeter. It needs to see low resistance (around 6 ohms or less in order to flash at normal speed)
Originally Posted by BoatRacer
I think the flasher fuse/relay needs to see the resistance from the bulb to flash? Your meter is dose not provide a load, it's just measuring incoming voltage.
First sentence is incomplete.
Flasher relay needs to see
low resistance or enough current. This means
low (a few ohms) resistance of conventional bulb allowing more current OR
low resistance (I believe around 6 ohms) of the shunt resistor used with LED's.
If relay sees
high resistance, as in using LED's only, it would flash fast.
Second sentence is
correct. Flasher relay sees Multi-meter as a high resistance = no load like an LED bulb. It should flash faster.
Originally Posted by SV_Dude
Find a 55w household bulb and solder some wires to it to make your own quick and cheap test bulb. I could be wrong but I would think you would hear the relay open and close though but maybe not with this type of relay.
I wonder if FSM means 55W-110Volt bulb or 55W, 12V auto bulb?
