Old 12-09-2013, 11:35 PM #1
mistersnowman97's Avatar
mistersnowman97 mistersnowman97 is offline
Real Name: Jerry Reed
mistersnowman97 is on a distinguished road
Rear Axle Leak
Just did a brake job on the front.
Front Pads were down to NOTHING. Need rotors at this point, but not gunna worry bout em til later.
Then I checked out the drums, and those seemed fine. Lots of extra pad left. Didn't replace em. That's for another day. Although, when pulling off the brake drum on the right rear, the drum was saturated with some type of oil. (guessing diff oil) Cleaned up the drum with some intense brake cleaner, so its mighty clean now, but the passenger side rear axle is still pretty wet. It's not dripping at all, so I'm not too worried. I'm assuming it's a seal that's gone bad, but I'm not sure. What do you guys think?
Here's some pictures from the job, sorry I didn't include any of the oil mess.
1994 4Runner-Stock 3VZE
mistersnowman97 is offline   Reply With QuoteReply With Quote
Old 12-09-2013, 11:52 PM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Rear axle could be either brake fluid or if its gear oil it would be a faulty inner axle seal. Not to terrible to change, you can download the factory service manual from a link on the top of the classics forum.
Check your rear breather. If its clogged the expanding air/oil inside will push out a seal. Cleaning it out man solve the issue, but thats a long shot.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 12-10-2013, 03:11 PM #3
Thanks I'll check it out. But I can't find my FSM.. The page says you have it! PM me and I'll give you my email
Old 12-10-2013, 06:41 PM #4
crash813 crash813 is offline
crash813 is on a distinguished road
Its its gear oil....its an axle seal.....if its brake fluid.....its wheel cylinder. If you don't know the difference...look up you tube for wheel cylinder replacement. That would be my guess.
1989 4runner V6 - Restoring from near death!
Build Thread HERE
crash813 is offline   Reply With QuoteReply With Quote
Old 12-10-2013, 08:51 PM #5
I know for a fact that it's diff oil. Definitely not brake. I just was asking what kinda repair I'm looking at.
Old 12-10-2013, 08:53 PM #6
there's also no real purpose in replacing the wheel cylinder if the brake pressure is uneven though IMO
Old 12-11-2013, 04:05 AM #7
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Pull the wheel, disconnect the brake hard line and ebrake cable. Four bolts hold the axle shaft to the axle tube, pull them and yank the entire brake drum and axle assembly out of the axle tube. It'll be heavyish, and slick with gear oil, so don't drop it. Set it aside and pry out the old inner axle seal from the axle tube. Install the new one. Reverse the process to put everything back together.
Don't let the axle shaft rest on the new axle seal while you're sliding it into the truck, or you could damage the seal and cause another leak. Now would be a great time to replace the brake shoes and clean out the inside of the drum really well (beware of gear-oil-soaked asbestos!).
Also, this thread would be tons easier to read if you'd put a line break between the pictures in your first post so they don't stretch off to the right for infinity.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Help with Rear axle Seal leak!! fightman80 3rd gen T4Rs 20 05-03-2013 06:40 AM
Rear Axle leak and whine. Norridgewockian 3rd gen T4Rs 15 12-17-2011 03:22 PM
Rear Axle leak 1pcguru Classic T4Rs 1 10-13-2008 09:26 AM
Rear Axle Seal Leak Dbiz 3rd gen T4Rs 8 09-21-2008 08:38 PM
