12-23-2013, 06:41 PM
Winter Maintenance Thread......
Thought there might be others out tackling repairs and service in the cooler temps. I started the other day by doing the following:
1) set tire pressures (they were low!)
2) did annual oil/filter change (castrol syntec 10w-40, toyota filter)
3) changed trans fluid
4) flushed brake fluid
5) changed p/s fluid (M1 syn atf)
Gave the truck a good wash and cleaned out the interior(it was time). The restoration bug has hit me, as I've ordered new factory rear mudflaps to install. 20 years of use have taken their toll on the originals. Ordered new front brakes (rotors,pads), front seals, and gaskets to repack the front wheel bearings. Thought it was time after 40-50k. Next year I'll tackle the steering system(pump, inner/outer tie rod ends, idler assembly, etc..). Hope everyone is having a nice Holiday.
regards
12-23-2013, 07:00 PM
Real Name: Cory
Real Name: Cory
I always replace my coolant right before winter. You might want to consider doing the trans filter next time you change your ATF.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
12-23-2013, 07:07 PM
eh. with modern coolants, i don't change them yearly. good for 100K, anyway, at which point it's usually time for a timing belt/chain along with new water pump, so the coolant gets changed then.
i do oil changes on mileage, not time of year. same for transmission, x-fer case, and diffs.
i check my tire pressure (and adjust if necessary) on a weekly basis.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
12-23-2013, 07:30 PM
Totally agree. I just did the coolant(toyota long-life with distilled water) not long ago (9 months ago) when installing a new factory rad. There is a trans kit on the shelf in our garage. My plan is to use it next year and convert the trans fluid over to M1 syn ATF. The fluid in our trans is quite clean, as it's changed every year. Thanks.
regards
12-23-2013, 08:25 PM
Real Name: Charlie
Real Name: Charlie
Make sure the windshield washer fluid is the non-freezing type and not filled with water.
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
12-24-2013, 04:06 AM
Originally Posted by Hyde802
Grease drive shafts and ball joints...
Oh hell yes! That's what we call it at home too - greasing the drive shaft and ball joints!!!
"People sometimes mistake their own shortcomings for those of society and to want to fix it because they don't know how to fix themselves."
Sir Isaac Asimov
Honey Badger Build Thread
12-24-2013, 02:50 PM
regards
So are you supposed to use toyota red in a 93 or is green fine?
12-24-2013, 06:36 PM
I would use the Toyota Long Life Coolant. It's not terribly pricey, and the results, I think, are much better then standard green coolant (ie Prestone or the like). Over the years, Long Life coolant seems to really hang in there (acidic wise), whereas, the green really seems to go bad much faster along with increased calcification.
regards
12-26-2013, 05:09 PM
Ok so I went down to my dealer today to get a part for my spouses 4runner and I asked about 1 gallon of coolant and its $40 unmixed. How much is it for other people?
12-26-2013, 05:13 PM
Real Name: Al
Real Name: Al
Winter?? What the hell is that haha
Mall Rated
'85 dlx- diy sliders, Addicted Off-road rear bumper, Spooled rear, OME rear springs, pro comp fronts, Killer Toy Tops bikini top, 33s
12-26-2013, 07:23 PM
concurrent with using washer fluid that is good for below freezing make sure to change over to winter blades for the wipers. they do work better than summer blades in ice and snow.
12-26-2013, 07:26 PM
autohausaz.com has the long life coolant for $27(no affiliation). I'm usually ordering a bunch of other stuff, so they usually ship for free. You might check around, there are a bunch of retailers that will carry it. Best of luck.
regards
12-26-2013, 07:30 PM
I can't get long life cheap our family friend is a local mechanic and owns his own shop but I know that toyota red is really the best. Thanks for the info
