11-26-2018, 03:21 PM
#211
Originally Posted by Hyde802
Thats wicked! Cant wait for a video to hear it!
hopefully i'll get some in a few weeks when I take it up again. but, I think the old engine sounded better. sadly. this ENGINE sounds better for sure, but the exhaust note not quite as good.
its flowing a shitton more air, plus this is the HO/351 firing order. its different from the old 302 order, and thus the exhaust note is different. it still sounds good, don't get me wrong, I just think I liked the old one better. lol.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
12-26-2018, 07:47 PM
#212
just a quick run down the alley.lets see if this works...edit: ok it didn't work, but here is the direct link.
YouTube
02-11-2019, 04:18 PM
#213
found a bit of snow on Saturday...
YouTube
02-11-2019, 08:37 PM
#214
nice little pass on the outside. im loving my new engine!!
YouTube
09-24-2019, 03:01 PM
#215
well, bad news. the poor old 4runner has finally died. the timing chain broke on the way to the mtns last Thursday. cruising along in 4th about 35mph, and it just died.
pulled the cover, the tensioner is blown apart, and the chain is broken.
I did a leak down test, and somehow, no bent valves. but, it already had a low hole, and leaks/burns a lot of oil. im just going to pull it, and rebuild it.
just over 300k on the rig and about 160k on this engine. it had been replaced with a remanufactured long block just before I got it some 20 odd years ago..
09-24-2019, 03:05 PM
#216
my slow build/wheeling/everything thread.
Keep it going man!
09-24-2019, 03:24 PM
#217
Originally Posted by 4Reak Show
Keep it going man!
I will. it will live again soon.
though, ive been wanting to swap a 3.4 into this thing. I was hoping this old 22re would last until I was able to do that. but right now, that's just not an option. I will just do a basic rebuild, and get it working again. then start collecting my 3.4 swap parts.
after the built v8 in my 85 truck, it will be hard to be "ok with the 120hp out of this 4cyl. haha.
09-24-2019, 11:01 PM
#218
Dang man. Yeah you can't think of the 3.4 for power. Its sole purpose is reliability and ease of maintenance. Even with a SC/7th/tuned 3.4 it won't even have that v8 feel. There is no replacement for displacement.
09-26-2019, 03:08 AM
#219
Real Name: Jeff
Real Name: Jeff
No! I'm glad it'll get the love it deserves. Good luck with the rebuild.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
09-26-2019, 02:00 PM
#220
for this rig, I don't necessarily need/want v8 power. though I did briefly consider a 1uz lol.
the 3.4 in stock form will have plenty of power I think. ive been running this thing with the 4cyl for many years, and the last few its been pretty tired. the jump to a properly running 3.4 would be pretty big im guessing.
that's how I felt. though, its my own fault, I have "thought about" the timing chain for a while now. I just didn't want to do it. plus with it being down on compression on one cylinder, fixing the chain didn't seem to be a priority. now I get to fix all the things. lol.
thanks man. financially, im really NOT in a position for doing this, but I need my 4runner back! so I will make it happen.
01-14-2020, 05:05 PM
#221
change of plans. I am now looking to swap in a 3rz. a much easier swap. hopefully getting a complete wrecked Tacoma soon...
01-14-2020, 05:11 PM
#222
01-16-2020, 12:15 PM
#224
Nice vid! jealous! Still waiting for real snow over here on the right coast.
thanks.
we are finally getting snow worth wheeling in. that trip was 2 feet of fresh from the night before. they are expecting another 20 or so by this weekend. should be good!
01-17-2020, 02:55 PM
#225
I wheeled it that way for a lot of years, then decided I needed bigger tires. so I ordered up a set up 36x12.50x15 super swamper TSL SX's and a skyjacker 5" lift to fit them. Tutuapp 9Apps ShowBox
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
