Old 01-29-2014, 02:28 PM #31
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Nice snow videos!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 02-03-2014, 05:29 PM #32
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by Hyde802 View Post
Nice snow videos!
thanks.
I got some more this weekend, this time in my truck.
pretty sure those aren't in order lol.
there are a couple more uploading now.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 02-03-2014, 05:39 PM #33
nevada's Avatar
nevada's Avatar
oh, as much as ive praised rugged ridge winches...
mine no longer free spools. the lever turns, but it never releases the drum.
I did a bit of research, im pretty sure its just a pin. possibly bent, but I think its slid out of place, causing it to be locked in at all times.
my truck has set on my trailer for over a year, I was slightly concerned some corrosion may have set in, and wasn't sure if it would work.
I ended up using it a few times on Saturday, other than the free spool issue, it worked great. its fairly quick, so I don't really miss the free spool option too much. I intend to pull the end cap off and check it. that in itself is easy, but unfortunately, due to my bumper design, I have to remove the winch completely for this. damnit.
i'll try to get some pics of this when I tear it down.
also, even with that issue, I wouldn't hesitate to buy another.
I think FOR THE MONEY, there isn't a better one out there.
hopefully the RR 10.5 I just got is equally as good.
Old 02-03-2014, 11:44 PM #34
nevada's Avatar
nevada's Avatar
a couple more vids from the last trip. the snow got pretty deep in places.
these videos actually came before the ones I posted above. oops.
love that sound!
Old 02-04-2014, 12:35 AM #35
mistersnowman97's Avatar
mistersnowman97 mistersnowman97 is offline
Real Name: Jerry Reed
mistersnowman97 is on a distinguished road
@nevada
please! post these on the video thread with a sticky Video Thread
1994 4Runner-Stock 3VZE
mistersnowman97 is offline   Reply With QuoteReply With Quote
Old 02-04-2014, 12:40 AM #36
nevada's Avatar
nevada's Avatar
Originally Posted by mistersnowman97 View Post
@nevada
all of them?
no 4runners tho...
Old 02-04-2014, 05:04 AM #37
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Originally Posted by nevada View Post
no 4runners tho...
you fired
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-06-2014, 03:25 PM #38
nevada's Avatar
nevada's Avatar
ok so I tore the winch down yesterday.
first a couple things:
I think it was my 1st or 2nd time using it, but the cable got wound up all on one side(thanks spotter), and put pressure against the connecting bar that goes across the top, and snapped the mounting ear off. OOPS. totally my bad.
I have been using it like this for a few years now, and haven't noticed any separation, or any other issues. which means the rear bar, and base are doing a good job keeping things in place.
the other thing, since new free spool worked, but it took quite a bit of effort to pull the cable off, and there was also a bit of a hard spot. it was just a PITA. I just kept it locked and powered it out. its fairly quick, so hasn't been an issue.
a buddy has the same winch, and said his free spool has never worked since new, and asked me about mine. last weekend while wheeling, I tried to use it, and NO GO. even with my foot against the bumper, pulling as hard as I could I couldn't budge the drum.
now to the tear down to find out WHY.
start by removing the 10 4mm cap screws, with a 3mm allen wrench.
once the screws are out, the cap just pulls straight off.
leaving you with this.
the inside of the cap, showing the heavy grease, and free spool lever.
there is the small gear at the end, its just sitting there, pulling it straight out.
then there are 3 sets of planetary gears.
this is with the first(smallest one) removed.
oh, I didn't get a pic of it, but after you remove the first gear set, you can then easily remove the outer main gear. the one with the scallops around the outer edge.
and here with the last, largest removed.
apparently I forgot to get a pic with the second one.
and lastly there is a smallish gear right in the center, you can see it in the last pic.
here it is removed.
now we can see inside the drum. what a mess!
I tried to used a flashlight and get a pic down inside the drum to show how bad it was. its hard to see in the pic, but the entire inside of the drum is coated. probably 1/4" thick all the way around.
anyway, as I pulled the parts out, I layed them IN ORDER, and in orientation on a rag.
I found out as I was cleaning things, that this wasn't entirely necessary, as it will really only go together one way. but, its good practice just in case its not so simple.
down to the cleaning. this "grease" was terrible. I would say it was closer to glue than grease. I cut the bottom off a plastic antifreeze jug, and soaked the parts in brake cleaner. then transferred them to the parts washer, and then one more time in the brake cleaner. it was a bit of work, that is nasty, sticky grease.
but finally, clean parts!
before these were cleaned, I could barely turn those individual gears. the grease had them glued in position.
cleaning the inside of the case was a bit more difficult, as I couldn't soak it, and those gear teeth in there were a *****. I ended up using a small screw driver and scraped one spline at a time.
now, as to why it wouldn't free spool, I had an idea that the pin in the lever had bent/broken/fallen out.
once cleaned up, you can see things are as they should be.
the pin is intact, and the lever turns freely.
i had read other threads online, that said the pin was bent, and this caused the issue. for the hell of it, i removed the pin. it slid easily, out so far, then stopped. weird.
i finally used a pin punch and removed it.
sure enough, it was bent.
except, its more CURVED then bent. i think this is done purposely to prevent the pin from sliding out during use.
i didn't realize this at the time, so for piece of mind, i replaced the pin with a roll pin. it went in with a bit of force, as a roll pin should. theres no chance it will just slide out. i believe a roll pin should have been used originally.
so the free spool lever turned, but it still wouldn't free spool. mechanically, that's not possible due to the design.
the free spool lever has a small, just over half circle on it, this locks into the scallops on the outer gear, thus locking them together, TO the outside case. letting the motor drive the gears, which turns the drum.
when in the free position, the half circle turns into a void, placing the flat spot in the scallop, and leaving the outer gear free to move/turn, thus allowing free spool. the motor is no longer engaged to the drum.
quite genius in design really. it takes very little pressure, due to the compound gearing, to lock that outer gear to the body of the winch.
also note how small the drive shaft is. i didn't measure it, but id guess its 5/16". this is with a 5.5 hp motor, and a 8500lb rating. again, this is due to the compound gearing.
i greased everything back up with some NLGI EP #2 grease. basically its wheel bearing grease that we had here at the shop. most places online suggested aeroshell #17, or moly1. but, any EXTREME PRESSURE grease should be fine. and really, just about ANYTHING will be better than what was in there. i didn't get any pics of this, obviously i was covered in grease.
oh also, most places say to "not use too much grease" because it will make it hard to free spool. well, i packed that ish in there. anything that moved, turned, touched, or rubbed got a liberal coating of grease. i made sure to spin all the gears until they spun freely.
install is the opposite of the tear down, the only thing id like to note is the 2 plastic shims.
seen here.
they go over the center gear, top left.
that's pretty much the only thing that can be put in incorrectly.
ok, so i mentioned when new, free spool had a hard spot.
one of the 3 gears on this set was hard to turn. it would turn about 75% of the way easily, then get hard. i think the pin is slightly bent. i was able to turn it with my fingers, but it got pretty hard. i think that explains the hard spot.
one last thing,
i haven't torn down many other winches, so i cant say if this is an extra feature, or standard for this design. but in the pic, the upper middle and left gears, you can see a large C-clip.
the center gear is staked into the plate, that C-clip prevents it from backing out. a pretty good idea, makes it that much more durable.
ok, so this ended up longer than i expected. but at least i had pics.
also, even tho i had the camera IN MY POCKET i still forgot to take pics of some things...
later today im going to tear down my new rugged ridge 10,500, and clean and regrease it.
i think this is something that should be down to ALL winches when new. regardless of brand, or price.
its a bit different design, so i'll take pics again. i'll try to keep the write-up shorter tho.
Old 02-06-2014, 03:37 PM #39
Real Name: Kevin
Real Name: Kevin
You've got me tempted to tear mine down now, and I haven't wired it up yet.
Old 02-06-2014, 03:48 PM #40
nevada's Avatar
nevada's Avatar
do it. i haven't heard of one yet that had GOOD grease in it from the factory.
i just pulled the cap off the 10.5, its got the same sticky glue/grease in it.
it did free spool decently, but it should work much better when im done.
also, it should run faster, and have a bit more power, since it doesn't have to overcome that sticky crap.
Old 02-06-2014, 03:57 PM #41
Real Name: Kevin
Real Name: Kevin
What grease are you using instead?
Old 02-06-2014, 03:59 PM #42
nevada's Avatar
nevada's Avatar
oh, i totally forgot.
it free spools very nice now. it wasn't mounted to anything, just sitting on the bench, i held it in place with one hand, and pulled off a few feet with the other. it worked well, even with the liberal amount grease i used.
also another thing, the 4mm screws are SS. not sure to what grade, but they are non magnetic.
Old 02-06-2014, 04:01 PM #43
nevada's Avatar
nevada's Avatar
instead of what?
maybe you missed it in the mess above..
but,
Old 02-06-2014, 04:04 PM #44
Real Name: Kevin
Real Name: Kevin
Yup, I missed it. Thanks.
Old 02-06-2014, 04:12 PM #45
nevada's Avatar
nevada's Avatar
oh yes,
the reason it didn't free spool, is because that outer gear was essentially glued to the case with the thick nasty grease.
the lever was functioning correctly, the grease just wouldn't let it spin freely.
which goes to show how little pressure is required to lock it in gear.
My slow build thread scottblink23 4th Gen T4Rs 45 06-04-2020 02:22 PM
Nate's Slow Build/Mod Thread 02_SE_Runner 3rd gen T4Rs 46 10-12-2014 04:42 PM
SixShooter slow Build thread TheSixShooter 3rd gen T4Rs 6 04-11-2013 04:19 PM
finanalyst17 slow build thread Finanalyst17 4th Gen T4Rs 2 02-23-2013 06:48 PM
TXTRDTEEJ's Slow Build Thread TexasTRDTeej 3rd gen T4Rs 1 01-20-2013 07:53 PM
