Old 02-06-2014, 08:58 PM #46
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
oh, I also forgot to mention why free spool is so important on winches with this style of brake, which from what I could tell is MOST of them.
its an automatic, ONE-WAY brake. its designed to hold up to 50% of the winch rating. ONLY in reverse.
every time you power the winch OUT, you are working against the brake, and wearing it out.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 02-07-2014, 02:02 PM #47
nevada's Avatar
nevada's Avatar
I pulled the 10.5 apart yesterday, it has the same sticky glue/grease.
altho it did free spool decently, I cleaned and regreased it.
the end cap was really stuck on there good. I had to drive a razor blade down in behind the gasket to get it to break free.
the large planetary gear set in this one was probably 75% larger than in the 8.5. the middle one may have been a bit bigger, and I think the smallest one was the same size/part.
beefy. all the gears spun easily.
along with the outer/small planetary, they also shared the same inner gear, and driveline. as best I could tell, they were the same part, I didn't measure anything and im too lazy to look up the part numbers to confirm.
a few things to note on this one,
the free spool feature. it uses a sliding collar. I don't like it. it doesn't seem as positive, or as easily switched as the other one.
its working nice and smooth there, but later, when I turned the drum a bit, it didn't engage as easily. it may end up being just fine as I actually use it.
also the lever itself is a bit floppy. I may try to replace the set screw with a larger one, to see if that tightens it up a bit. there is an o-ring on it, to keep crud out, but the lever is so sloppy, it doesn't really touch.
a bad cast. its in an area that shouldnt cause any issues. I expect I just got unlucky with this one, I doubt many/all are like that.
the above 2 issues are things I wouldn't expect to find on a more expensive winch tho.
and lastly, once I got the end cap cleaned up, I noticed this.
interesting. id read rumors about them being the same. pretty sure the box says "made in china" but t-max is an Australian company...
Old 02-13-2014, 04:01 PM #48
nevada's Avatar
nevada's Avatar
ahahaha. I found the specs for my old MM winch.
Mile Marker e8000 Electric Winch
2hp motor and 13fpm line speed.
that's just sad. oh, and free spool didn't work on it either. lol. we had to power it out every time. I guess that explains why our trips were so long. we were still winching. haha.
Old 02-17-2014, 05:00 PM #49
nevada's Avatar
nevada's Avatar
we found a little snow...
Old 02-18-2014, 06:59 PM #50
nevada's Avatar
nevada's Avatar
oh yeh, I mounted the new 10.5 winch for that trip. we ended up using it quite a bit, but no really bad stucks. but it worked well.
the thing I noticed tho, was how quiet it was. im sure its because of the good grease. sitting in the cab, with my buddy winding it back on the drum, I couldn't even tell the winch was running.
I wired a switch out on the front, so whoever is working the cable, can power the winch, so I literally didn't know the winch was running.
id like to make note, that is one of my favorite mods. I have the same switch inside the cab. have had for years, but the one out front is new, and its SO NICE.
I may never use the remote again.
Old 02-25-2014, 12:49 PM #51
nevada's Avatar
nevada's Avatar
I finally got around to uploading them to photobucket.
a few more from that last trip.
we didn't get very many pictures, the snow was deep, made it hard to walk around. she should have some snowshoes for this next trip
Old 02-25-2014, 01:28 PM #52
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Looks like slow going in snow that deep. Looks like a good trip!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 02-25-2014, 01:48 PM #53
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I don't get to wheel in snow that deep. Our mountains are too steep.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-25-2014, 02:29 PM #54
Dinardy's Avatar
Dinardy Dinardy is offline
Real Name: Andy
Dinardy is on a distinguished road
Dinardy's Avatar
Real Name: Andy
Wow. It looks like I need to make a trip over to the east side
2001 4runner SR5 4x4
1991 4runner SR5 4x4 Sold
1995 4runner SR5 4x4 Sold
Dinardy is offline   Reply With QuoteReply With Quote
Old 02-25-2014, 02:50 PM #55
nevada's Avatar
nevada's Avatar
yes, at times, we would only get 20' at a time.
that sucks.
there will be about 2 feet more snow this Saturday when we go. not sure how far up the road we'll be able to get...
Old 02-25-2014, 07:26 PM #56
Nuked Beaver Nuked Beaver is offline
Nuked Beaver is on a distinguished road
Where?
Where are you headed this weekend for that level of snow? The cascades or Olympics? Evans creek?
Nuked Beaver is offline   Reply With QuoteReply With Quote
Old 02-25-2014, 07:30 PM #57
nevada's Avatar
nevada's Avatar
I guess it would be the cascades. the nile/cliffdell area.
its just a county road, but they turn into trails once the snow gets deep
Old 02-25-2014, 07:45 PM #58
Dinardy's Avatar
Real Name: Andy
Dinardy's Avatar
Real Name: Andy
Not sure Evans is open yet, though if you take a left at the fork after the sketchy bridge and head towards the Snoqualmie Federation Forrest you may hit some.
Old 02-26-2014, 12:06 PM #59
nevada's Avatar
nevada's Avatar
heres another vid from that last trip. this was right before we turned around.
we could have worked our way up to the trail(at the end of the road) but it would have taken a long time.
Old 02-26-2014, 01:38 PM #60
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Aaaahh snow wheelin! Haha. I always turn my speakers up when you post a vid. Man that thing sounds good.
IG: rattlewagon
My slow build thread scottblink23 4th Gen T4Rs 45 06-04-2020 02:22 PM
Nate's Slow Build/Mod Thread 02_SE_Runner 3rd gen T4Rs 46 10-12-2014 04:42 PM
SixShooter slow Build thread TheSixShooter 3rd gen T4Rs 6 04-11-2013 04:19 PM
finanalyst17 slow build thread Finanalyst17 4th Gen T4Rs 2 02-23-2013 06:48 PM
TXTRDTEEJ's Slow Build Thread TexasTRDTeej 3rd gen T4Rs 1 01-20-2013 07:53 PM
