Old 02-05-2014, 07:52 PM #1
mjquillici mjquillici is offline
mjquillici is on a distinguished road
Common Vacuum Leaks?
I am pretty sure that I have a vacuum leak, causing my idle speed to remain elevated, even after the engine is warm. Where should I start looking?
My current plan is to systematically remove one vacuum hose from the intake at a time and plug the hole to see if an effect is observed on the idle speed. Does this seem like a logical approach?
1994 4Runner SR5
193,000 miles
3.0 V6, manual transmission
4-wheel drive, Warn Hubs
Moog springs, KYB Monomax shocks
mjquillici is offline   Reply With QuoteReply With Quote
Old 02-06-2014, 01:54 PM #2
turboSR5's Avatar
turboSR5 turboSR5 is offline
Real Name: Todd
turboSR5 is on a distinguished road
turboSR5's Avatar
Real Name: Todd
That sounds like a decent plan. Also check your elbow after the AFM and before the throttle body.
Another trick is the pressurize your intake tube. Pull the elbow at the AFM and use a large plug or something in the tube, give 4 psi and see if you can find a leak.
1986 4runner 22RTE Turbo SR5 - R.I.P.
1986 Extra-Cab Pickup DLX - Sold
1987 4runner 22re SR5
1984 2wd Exrta Cab
1982 BJ60
turboSR5 is offline   Reply With QuoteReply With Quote
Old 02-08-2014, 10:48 AM #3
bills86e bills86e is offline
Real Name: thanks
bills86e is on a distinguished road
Real Name: thanks
A common mistake is the 3 center passenger side under plenom tubes to hoses get mis-routed when the mechanic removes the plenom to service the pcv or valve cover gasket.
Pull the modulator cap off and clean its internal filter. Its function is to clean the air vacuum to the EGR. If you pull the top hose off the EGR and the engine smooths out, the VSV hoses are routed incorrectly.This is a mistake made by mechanics when the plenom gets pulled, replaceing the passenger side valve cover gasket or pcv valve. under center sticking out under passenger side plenom are these three tubes. One goes to the fuel regulator, and you get a foul smell from exhaust, poor performance also. Under the Bonnet (hood) on driver side is the vacuum hose routeing, but better pictures are posted online here.
Search code 71 and vacuum lines. - Page 2 - YotaTech Forums
The Blue VSV is to the PAIR, The Red (brown) is to the Fuel pressure up and the Green is to EGR. Consult the under hood front right vac routing sticker.
bills86e is offline   Reply With QuoteReply With Quote
Old 02-08-2014, 11:30 AM #4
Real Name: thanks
Real Name: thanks
Does it smooth out when ya pull the top hose off EGR valve?
Whats any recent mechanicall History?
Old 02-03-2016, 04:17 PM #5
Kanjozokutsu Kanjozokutsu is offline
Kanjozokutsu is on a distinguished road
Been searching for days about my bouncing idle. Haven't had any luck. Think I'll try this tonight after work.
Kanjozokutsu is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 03:42 PM #6
Jst183112 Jst183112 is offline
Jst183112 is on a distinguished road
I have a massive vacuum leak on the passenger side but I need a illustration to further diagnose what hose goes to what port where. Can you help?
Jst183112 is offline   Reply With QuoteReply With Quote
Oil Leaks jaybirdy2k Classic T4Rs 14 04-27-2012 03:28 AM
Leaks all over rbdhd 3rd gen T4Rs 7 04-02-2012 10:14 PM
Best way to check vacuum leaks? Gabriel33 Classic T4Rs 6 11-15-2011 06:34 AM
93 leaks kroo88 Classic T4Rs 4 04-21-2011 11:58 AM
Common oil leaks on front of motor? Daveed Classic T4Rs 7 01-29-2007 11:23 PM
