01-25-2006, 11:53 PM
front parking brake cable
Replaced front parking brake cable today. 73 $ and 4 hours later i now have parking brakes again. Anyone else have to do this repair? any problems it was easier than i thought
01-27-2006, 09:20 PM
4 hrs .... holy crap . I hope you learned a few things ....
01-28-2006, 04:18 AM
lol... probably would have taken me about 6. but yes, i didnt have to do it but the previus owner did
01-29-2006, 12:39 AM
Re: front parking brake cable
ya actually had most of lower dash apart and had to remove the actual pull lever to find out how to get the old barrel (the end of the snapped cable) out plus do this by myself in the dark at about 36 degrees but ya i didnt mind thats how you learn right
09-25-2006, 09:48 PM
What's the trick?
How did you remove the old cable from the rod?
10-11-2006, 03:33 PM
Pull the pin
In case anyone is wondering, you've got to yank out the pin from the pull rod, then you can rotate it freely. The pin that I mean is that small metal rod, flattened on the end which is inserted horizontally into the pull rod.
Also worth noting is that the brake light in the dash is wired in parallel with the brake fluid level sensor. In my case, since the brake light had been on for a while as the hand brake cable was broken, I didn't realize that brake fluid level had dropped a bit. It was only after I put in the new cable that I saw that the brake light in the dash was still on.
04-05-2010, 06:07 PM
Any tip on how to get that pin out? I tried to do this the other day and that sob is in super tight....also was there slack on your cable when you disengaged the parking brake?
04-05-2010, 07:18 PM
You don't have to yank out the pin. There's a button toward the front of the rod that lets you push the rod about 2 inches farther in, then you can hook the cable from inside the hood after removing the pulley. You do need to remove the switch for the light, or the prong on the rod that pushes the button.
The biggest problem I had was finding a new cable. The install itself only took me about 20 minutes and I'm not very good at auto work.
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
04-06-2010, 12:03 AM
So where did you find a brake cable, i am in the market to find one and replace my broken on my 93
04-06-2010, 12:41 AM
you should've done a write-up! i have to do mine soon too but ive been putting it off. not to mention my local dealership want 160 bucks for the damn thing
4Runner of the Month August 2006
1991 Toyota 4Runner SR5 V6 5 spd
Old Man Emu N98 Front Shocks, Old Man Emu N72F Rear Shocks, Old Man Emu 901 Heavy Duty Coils, SDORI Ball Joint Spacers
Eagle Alloys Series 185, Toyo Open County M/T, Aisin Manual Hubs
Sony CD/MD Double-Din HU, Sony 12inch Sub, Sony 1200W Amp, XM Satellite Radio, Xantrex XPower 1000W Inverter
JDM Inclinometer, Hella 550 Fog Lamps, Wayfinder V7000 digital compass, Cobra 19 DX IV Citizens Band Radio, 4' Firestik Firefly CB Antenna, Magellan Triton 1500 GPS
04-06-2010, 12:59 AM
To get the pin to come out I just grabbed it with a set of needle nose pliers and pulled it right out. At the time the cable had snapped, so there was slack.
04-09-2010, 06:26 PM
Yeah where did ya find a replacement cable, I just busted mine!
04-09-2010, 10:45 PM
I got mine on ebay. But you should be able to get them directly from a Toyota dealer.
04-15-2010, 09:49 AM
I found mine on toyotapartszone.com for $58.56 with UPS ground shipping, got it in yesterday and putting it in this weekend. i will let you all know how it goes.
1993 4Runner, SR5, 22RE, 195K and running strong
02-21-2012, 09:08 PM
Old thread, but I'm dealing with this on my '92. Just as an FYI, there are spines on the pin that you need to pull out to rotate the parking brake handle a little further to get the cable unhooked. So this pin needs to be pulled straight out, not twisted.
I tried pulling it straight out with a set of visegrips and didn't have any luck. After twisting it, I broke the pin
After looking under the truck and unhooking the other end of that front parking brake cable, it looks like putting in a new one will be difficult since there are connectors on each end.
Any suggestions? I was going to practice on mine before heading over to pick-n-pull, but I might just try fixing or welding the cable back together.
92 4runner SR5 Garnet Pearl (3K3), 5spd 4x4 V6 185k
22 Sienna AWD 9k
06 Sienna AWD 185k
98 4runner SR5 4x4 V6 auto 136k locking rear diff -- SOLD (and heard it's been totaled)
