Old 02-12-2014, 09:53 PM #1
Orlanda Orlanda is offline
Orlanda is on a distinguished road
replaced fuel pump- still won't start. help?
I recently paid way to much for an 88 4runner on the understanding that the guy I bought it from would help me out with anything more involved than reg maintenence. Also took his word that the engine had been replaced with one w lower kms, doubting that now too...
Anyway. The fuel pump went. I figured that was the issue as it was getting power but not coming on when turning engine over. Replaced the fuel pump. Tested it. It's working. Truck still will not start. I don't know what to say it's a bit of a Frankenstein but I'm not totally mechanicly retarded so can usually figure out stuff given enough time and info.
That being said, do I need to bleed the system? Prime the pump? I thought the electric pumps didn't need priming so I just swapped it out and put it back together...
Any help would be greatly appreciated.
Orlanda is offline   Reply With QuoteReply With Quote
Old 02-12-2014, 11:48 PM #2
fourwd1's Avatar
fourwd1 fourwd1 is online now
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
There are some interlocks on the power to the fuel pump.
You can bypass them by jumpering the +B and Fp terminals of the test connector, which is located adjacent to the engine bay fuse box.
Then check to see if your getting fuel to the fuel rail.one way to do that is pull the cold start injector and see if its spraying.
'89 4Runner SR5 - stock
fourwd1 is online now   Reply With QuoteReply With Quote
Old 02-13-2014, 01:49 AM #3
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Fuel Pump wired properly?
A problem well-stated is a problem half-solved. What engine? If 22R-E, do as fourwd1 said above^^
Then, verify that fuel pump is wired properly. See schematic and explanation how it works with circuit opening relay here.
Then let us know what you find out, and we'll go from there.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 02-13-2014, 08:12 AM #4
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
What they said. Also, define "not starting" - it does nothing at all? Just clicks when you turn the key? Or it turns over but won't catch?
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-14-2014, 04:11 PM #5
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
Originally Posted by RAD4Runner View Post
A problem well-stated is a problem half-solved. What engine? If 22R-E, do as fourwd1 said above.
Same procedure for 3.0 V6
Old 03-01-2014, 12:58 AM #6
Blueaussie Blueaussie is offline
Blueaussie is on a distinguished road
Try placing some needle nose vise grips on the return line of the fuel regulator. If you block this return line and it starts you need to replace the fuel regulator and if so for Gods sake don't by a after market from auto supply house. save yourself the hassle and replace with original Denso unit. I learned that the hard way.
Blueaussie is offline   Reply With QuoteReply With Quote
help please! , new member , replace fuel pump
Replaced P/S Pump AND Reservoir...still leaking. SummerallGuard04 3rd gen T4Rs 13 02-12-2021 01:16 AM
First start on replaced engine mliebal 3rd gen T4Rs 2 09-01-2013 03:03 PM
replaced fuel injectors Wow! willyt4r Classic T4Rs 20 12-11-2012 02:54 AM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
