Originally Posted by bagelsjustbagels
Rock Lights installed. Bought leds waterproof 3 part segments from china for $3 a piece and installed 6 white and 2 red wired it to a switch, and bought 16 guage speaker wire to run the 12v around the truck.
also correct size pictures. yay!
Okay you've officially motivated me to long travel my 2nd gen!! Holy shit, this thing is RAAAAAD!!
I understand the front end modifications with the Total Chaos kit rather completely, however, I'm still figuring out what needs to happen to the rear end... Mind if I ask a few questions?
1) So you did a leaf spring conversion. Did you keep the stock axle and 8" differential?
2) Track width: Now that the front is 6+ inches wider, did you match that width in the rear? Or just go with a wider front than rear?
3) Fiberglass: I really like what guys are doing on these with the front fenders, but on these 4Runners, it seems way harder than on the pickup configurations. I see on yours that you don't have any aftermarket rear fiberglass. What are your thoughts on this? Also, is your hood an aftermarket fiberglass one, or did you modify the OEM hood to have the scoop?
4) Can you advise on brands and sources for the coil-overs, and bipass shocks?
Again, freaking awesome build man!! You just need to throw a supercharged 3.4 in that thing now ;)
Here's my SC'ed 3.4 swapped Runner that I've been dreaming of adding LT to....
