Originally Posted by Hyde802
A leaking rear main seal means your clutch is getting oil soaked, which will shorten its life. After you shut the truck off, is there smoke coming from under the hood? Can you smell burned oil? Those are usually sings from a very bad valve cover.
Really need to identify the leak. Get some simple green and some rags and have at it. Clean everything. Then start it up and watch to see where the oil comes from.
Or you can get some cans of brake clean and put a oil pan under where your spraying. Lots faster easier and drys just about instantly
