04-17-2014, 07:41 AM
#16
Originally Posted by KidVermicious
I'd love to get your impression on the fit and finish after you've installed them? I used their front crossmember brace instead of going with 4xInnovation, and I wasn't impressed at all.
The upper mount is a fairly new product I'm sure, there is really no info or review on the web other than their website which states trimming for fitment will probably be necessary. A friend of mine was unable to use it for some reason I am not sure of. I suspect the proportioning valve on the frame is in the way, which I am removing anyway. I plan to add plate where it welds to the frame to reinforce it.
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
04-18-2014, 02:39 AM
#17
Thanks!
04-18-2014, 01:00 PM
#18
Real Name: Sam
Real Name: Sam
Are you talking about Jerret's truck? Im kinda interested to see how that upper mount works for you aswell. I was going to order it from LRO, but Jerret said theres a lot of modifying to get it to work for some reason. I have actually seen an install on it yet, so i havent pulled the trigger on it.
Need Custom Decals? PM me.
1984 Toyota Pickup SR5: 22r dual fuel propane/gas, 5-speed, 35s, RUF lift, TG high steer, Chevy 63 rear swapped, 5.29 gears, longs, chromo shafts, aisin hubs, 4.8 T-case, twin sticks, addicted offroad bumper, homemade sliders, arb front locker, aussie rear locker.
1989 Toyota 4runner SR5 Daily Driver: 3.0 5-Speed, 35s 4inches of lift (still chicken winged) sliders, arb front locker, 5.29 gears, chromo rear shafts
04-18-2014, 02:59 PM
#19
Yea Jerret. I have a feeling the brake proportioning valve and exhaust kept him from using it.
05-27-2014, 07:37 PM
#20
I looked under the valve cover today. Oil leaks out of the timing cover where it meets the head. Well, I am missing the "bolt under the oil puddle". I don't even have an oil puddle there. Does anyone know what size bolt I need?
Also need to replace the PCV valve grommet.
#21
05-28-2014, 08:44 PM
#22
Got the old header out and realized I need a stud kit. Also ordered a rear main seal, shifter fork boot, socket and cup.
Here is the intake I pieced together
05-29-2014, 05:27 AM
#23
Real Name: Kevin
Real Name: Kevin
It's a 14mm head if memory serves, but I don't remember the pitch. Just rob the bolt from your other truck.
Nice header!
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
05-29-2014, 06:25 AM
#24
Nice header!
My other truck leaks in the same spot so I assume it is missing too. Never noticed it under the oil. Anyway it is an M8x50, I think 1.25 thread pitch, I just need to go get one.
05-30-2014, 06:00 AM
#25
Well that damn bolt is broken off inside the timing cover. I can see where sealant was applied to prevent the leak but it just doesn't work. Started taking everything off to pull the cover until a storm came.
05-30-2014, 06:18 AM
#26
Real Name: Kevin
Real Name: Kevin
Don't you love cleaning up after the PO? I wonder what other jackholery you'll run into.
05-30-2014, 06:37 AM
#27
Yes it has been so fun with both of my runners!
I am nervous what I will find as I keep digging, I have already found a few other ****ups. I can't blame the PO though. Obviously the shop that built this motor should find a new line of work. I have the paperwork for it.
05-30-2014, 06:39 AM
#28
Real Name: Brent
Real Name: Brent
Every 4Runner build should have beer included... Nice work!
That is a really nice battery box, I'll have to check them out for a second battery located in the back.
How's the front axle coming?
>>> The Expo Dawg Build <<< (SOLD)
New hotness: '04 V8 Ltd (No Build Page)
05-30-2014, 06:47 AM
#29
Damn straight, cold beer to keep me calm while I curse PO's, lol.
The front axle is built under the '85. Need to finish cleaning this frame and weld up the hangers and frame plates etc. I'm going to focus on the motor for now, take a break from grinding.
05-31-2014, 03:53 PM
#30
I can't believe someone did this, especially a "professional" shop.
Everything else looks good, so I'll just clean everything up, get a new cover and put it back together.
