04-07-2014, 08:34 PM
2wd front wheel bearings
Hey all. If anyone could give me any insight on changing the front wheel bearings and the tie rod ends, it would greatly appreciated. I've searched and searched this forum and can't find anything relatively helpful for a 2 wheel drive. I know how to change wheel bearings but in case there's a little trick, or tip, something I've missed. I'd like to know. Thanks!
Bone stock / 1995 T4R SR5 2WD 3.0 / 31x10.50 Cooper Discoverer AT3's / Daily Driver/Cruiser - Dothan, AL
04-07-2014, 10:07 PM
You can't find anything because there are about 2 members on here with 2wd 2nd gens. For tie rod ends just count how many turn it takes to come out and put the new ones in that much
1997 sr5 Mall crawler 3.4l 174,000
1993 sr5 3.sloooow 5 speed ome 2" rear coils slightly cranked torsion bars
04-08-2014, 09:04 AM
Real Name: Caleb
Real Name: Caleb
Counting threads only works if they are the exact same tierod, different brands will have different number of thread/shank length. You can align it in the drive way with a tape measure (Google, driveway alignment). But it probably best to have a shop do it.
IIRC, 2wd and 4wd runners are the same, just one does not have a front diff/cvs.
A thin walled 54mm socket makes a huge help with removing the nuts on the wheel bearings. You can get one from Trail-gear for about $12
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
04-09-2014, 12:14 AM
Thanks! So I ordered both both sides inner/outter bearings and got my hub apart today, found out I had the wrong bearings. My old ones seemed to check out ok so I just repacked them and put it all back together. Took about 20 minutes. I didn't think it would be that easy. I'm gonna replace both sides inner/outter tie rod ends tomorrow. I'm debating on whether or not I need a new pitman and idler arm.. They both have play.. But it's hard to tell what has play and what doesn't..
04-09-2014, 12:16 AM
And I'm just going to measure total length of inner and outter tie rod assembly, and go from there. Seems like it's a good idea. Lol
04-09-2014, 12:56 AM
Real Name: Cory
Real Name: Cory
If they both have play, they both need replaced. Otherwise your alignment wont last.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
04-09-2014, 07:48 AM
I'm gonna have someone move the wheel today while I've got it jacked up to see. I really don't wanna change that pitman arm but if need be, I can do it.
04-09-2014, 12:18 PM
So I'm replacing everything but my drag link tonight. Wish me luck! Getting alignment done on Friday.
04-09-2014, 12:28 PM
I haven't worked on a 2wd yet, but if they are anything like the 4wd, good luck getting the pitman arm off the box. they are REALLY stuck on there.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
04-10-2014, 12:10 PM
Yeah.. Couldn't get the pitman off. So I just left it. It didn't need replacing anyways.. Got the rest of done in 3 hours.. First time doing any of that. I feel accomplished to say the least. Lol next thing I'm going to tackle is the ball joints.
04-10-2014, 12:36 PM
Real Name: Todd
Real Name: Todd
I have busted a couple of pullers in the past. I dont even bother to use them anymore. Take a hammer in each hand and time your swing to hit the pitman arm right on the fat part that is holding the shaft. When you time it right and hit it with both hammers at exactly the same time: the pitman arm just falls right off. You don't have to swing the hammers all that hard either, timing is more important than speed to ripple the metal enough to shake it loose.
1986 4runner 22RTE Turbo SR5 - R.I.P.
1986 Extra-Cab Pickup DLX - Sold
1987 4runner 22re SR5
1984 2wd Exrta Cab
1982 BJ60
