Old 05-27-2014, 07:31 PM #1
Gremcat Gremcat is offline
Gremcat is on a distinguished road
AC Power Steering problems?
I had my AC fixed and now when I first turn it on it squeals for a few minutes. Not a big deal but I noticed a leak on the driveway about a week ago. Fast forward to today and I finally got around to looking at it. I assumed Valve cover because my friend that went through the truck after I bought it mentioned one was leaking a little. It is actually the back side of the Power Steering pump leaking like crazy. Is it time for a new Power Steering pump?
Gremcat is offline   Reply With QuoteReply With Quote
Old 05-27-2014, 07:38 PM #2
91'4bee 91'4bee is offline
91'4bee is on a distinguished road
Either a new pump or if a seal went bad then maybe you could repair it. Depends on how much money you want to spend or time you wanna put into it.
1991 4runner SR5 3vze 5 speed 4x4 with 150k original miles.
91'4bee is offline   Reply With QuoteReply With Quote
Old 05-28-2014, 10:53 AM #3
crash813 crash813 is offline
crash813 is on a distinguished road
I would go around and tighten all the connections on the pump. If they worked on the a/c, they probably removed some of the ps stuff to get to the compressor. There's a valve that connects to vacuum lines that I had problems with leaking. Usually if its a seal, its the front of the pump that leaks.
If just tightening doesn't fix, seal kits are cheap for these and its pretty easy to replace them all. The heat in the engine bays tend to kill the seals in these. Just make sure you don't run the pump dry or you will be buying an entire pump.
1989 4runner V6 - Restoring from near death!
Build Thread HERE
crash813 is offline   Reply With QuoteReply With Quote
Power Steering Problems DirtDawg 3rd gen T4Rs 16 01-26-2016 03:54 AM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Power steering problems AZ4runnerPrerunner Classic T4Rs 2 07-27-2013 09:07 PM
94 V-6 Power Steering pump problems edtheshark Classic T4Rs 4 02-18-2011 11:20 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
