Old 06-20-2014, 09:25 AM #1
Clone of the Mean Clone of the Mean is offline
Clone of the Mean is on a distinguished road
Bad fuel leak... Injector? Fuel Rail?
I tried a search and didn't have much luck.
I drove on the freeway yesterday for the 1st time in forever. Only a few miles at 65 MPH. I got home and everything was normal.
This morning I cranked and cranked the motor til it finally started. As I drove down the street I could smell gas so I turned around back home. I got out and there was fuel pouring out from under the passenger side of the runner. I popped the hood and the top passenger side looked pretty wet as well.
I don't know alot about FI, but I remember when I did the valve covers a few years ago it seems like the injectors just popped into place. It seems to run OK, maybe a little sluggish, but no miss. I'm thinking one just popped out, but that was alot of gas......
Any ideas?
Clone of the Mean is offline   Reply With QuoteReply With Quote
Old 06-20-2014, 11:49 AM #2
airdreams1 airdreams1 is offline
airdreams1 is on a distinguished road
there are several things that it could be....
could be a seal for the injector, a fitting, a hose, etc....
if you have an inspection mirror & a light. you could turn on the ignition (may have to be running) & look for the leak before you tare everything apart. even a cheap dental mirror might work. just depends on where its leaking from.
airdreams1 is offline   Reply With QuoteReply With Quote
Old 06-20-2014, 04:10 PM #3
will do. I don't want to remove the intake if I don't have to…...
Old 06-20-2014, 11:50 PM #4
So it turned out to be the cold idle hose coming from the fuel rail. $105 dealer only. I cut the ends off and am going to throw some fuel line on it and call it good….
I'm starting a new thread called "don't you hate it when"… I write my adventure there.
3.4 fuel rail installation question zgensler31 3rd gen T4Rs 9 10-29-2023 06:39 PM
Truck won't run unless tapping on the fuel rail Pbourgeois Classic T4Rs 4 11-25-2013 12:20 PM
bad fuel injector after fuel filter change Drcoffee 3rd gen T4Rs 18 03-30-2012 08:39 AM
3vz fuel rail bleeder FirstGenRunner Classic T4Rs 1 09-24-2011 12:51 PM
PG011R-05 06/09/2006 Fuel System - Fuel Injector Cleaning Procedure CBR_GUY_IA TSB 0 07-12-2009 09:44 PM
