Real Name: Charlie
Real Name: Charlie
There shouldn't be a problem using the turbo gauge cluster, although if yours has a 110 mph speedometer and the other has an 85 mph speedometer, you'll need to either get everything calibrated, or find the right cable and corresponding parts to convert it over. The other gauges should be the same, and the boost gauge will just read vacuum if you hook it up. Hope that helps!
